Question about Honeywell Heating & Cooling
Honeywell Thermostat DT90E display reads 'FAil' what does this mean as there is no reference to this in manual?????? What do I do??? Thank you for your time
    Brigadier General:
  • 4,736 Answers
If the compressor motor is overheating, it's usually a result of low refrigerant gas in the cooling coils. Recharging is an option, if you can find a shop that will do it.
Posted on May 22, 2011
What does 54NC mean when displayed on my Honeywell room thermostat?
I'm guessing, I don't have your thermostat, but "NC" sounds like, "Not Connected". Check wiring at back of thermostat and at furnace.
May 13, 2015 | Heating & Cooling
How to wire a DT90E honeywell thermostat
Let me know if you need anything else.
Dec 13, 2013 | Honeywell Heating & Cooling
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
I would like to know how to wire honeywell dt90e thermostat which wires where i have 5 wires from wall
It helps to know which wires went to the terminals on the old thermostat, if it had one. Otherwise, you would really need to know how they are hooked up inside the furnace/air handler. Some technicians hook them up differently, but I can give you the basics and most commonly used wires. R terminal- red/power wire G terminal- green/ fan wire Y terminal- yellow/ cooling or condenser wire W terminal- white/ heating wire C terminal- blue/black/ common or ground wire If you have a rc/rh terminal, they are usually jumpered with a small wire and your power wire still hooks to that. Hope this helps and good luck!
Jun 25, 2011 | Honeywell Heat/Cool Thermostat
Ive currently got a honeywell smartfit thermostat control which is displaying F24 which ive been told means i need to replace the control panel, again!! ive already replaced it once not so long ago (approx...
There are other universal replacements but if it was me I would stick with the honeywell parts. I know they are more expensive but in your instance where you already have a problem that is causing the control panels to fail I'm afraid you would make it worse by using other then factory replacements.Thank you
May 17, 2011 | Honeywell Heating & Cooling
Replacing a drayton rts8 to a honeywell dt90e thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Nov 18, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
603 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
