I don't have a aol disk to insert. most of this files are from 2003 2004 2005, any suggestion on that?I don't have a aol disk to insert. most of this files are from 2003 2004 2005, any suggestion on that?
You can't post conmments that contain an email address.
AOL Error 116 arise due to damaged Windows system files. Or another malicious application has erased the device files. follow the blog to get rid of this issue.
What Are The Causes Of AOL Error Code 116:-
Here are some common causes which result in Error Code 116.
Some damage caused in the file system in Windows OS.
Incomplete installation or uninstallation of applications or hardware.
Some malware or spyware attack may cause the error to occur.
Windows registry file system may get corrupted.
How To Fix The AOL Error Code? ' Step By Step Solution:
If you are facing the error code 116 of AOL, you will not be able to send and receive mail from your AOL email account. It is very frustrating for users when they face these kinds of errors with their email account as it prevents them in their personal as well as official communication. Hence, it gets quite urgent for the users to fix the particular error code issue with regards to their AOL. Here we have listed some of the common solutions which you can follow to fix the issue. In case you are unable to resolve the issue by yourself then call AOL customer support for quick help. Users do get AOL Error 116 due to some misconfiguration in system files of their Windows Operating system.
Best Solution:
Follow the below mentioned simple solution step by step to resolve the error code with AOL.
Start your computer and log in to the system as an administrator.
Click on the "Start" button and then "All Programs" menu.
Click on Accessories and then "System Tools".
Now click on "System Restore".
A new window will open and you need to select "Restore my computer to an earlier time" option.
Click on "Next". Select the most recent system restore option from the list of options displayed.
Again, click on "Next".
Keeping clicking till you reach the end of confirmation window.
Now, restart the computer to enforce the changes done.
The above-mentioned step by step solutions will surely help you fix your issue of code 116 of AOL. However in case you are unable to resolve the issue by yourself or get stuck at some point then call to AOL support service to help guide you through the steps.
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br>
<p><b><span> </SPAN></B><br>
<p><span>Open a Command Prompt window and leave it open.</SPAN><br>
<p><span>Close all open programs.</SPAN><br>
<p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br>
<p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br>
<p><span>Leave Task Manager open.</SPAN><br>
<p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br>
<p><span>At the command prompt type DEL <filename> where <filename> is the file you wish to delete.</SPAN><br>
<p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br>
<p><span>Close Task Manager.</SPAN><br>
<p><span>Or you can try this</SPAN><br>
<p><span>Open Notepad.exe</SPAN><br>
<p><span>Click File>Save As..></SPAN><br>
<p><span>locate the folder where ur undeletable file is</SPAN><br>
<p><span>Choose 'All files' from the file type box</SPAN><br>
<p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br>
<p><span>put a " at the start and end of the filename</SPAN><br>
<p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br>
<p><span>click save,</SPAN><br>
<p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br>
<p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br>
<p><span>1. Start</SPAN><br>
<p><span>2. Run</SPAN><br>
<p><span>3. Type: command</SPAN><br>
<p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br>
<p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br>
<p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br>
<p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
Try and download " Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors. ---adamdee
This sounds like you've got one of three things happening:
1 - Your USB cable is dying slowly. Over time connections become seperated within the cable. This causes data loss and all sorts of funny errors. Try a different cable and see if that helps.
2 - Your USB plug is malfunctioning or underpowered. If you are attempting to use a USB 2.0 device on a 1.1 connection, errors may prevent you from doing what you want to do. Try a different USB port, see if that helps.
3 - Your MP3 player has a setting somewhere locking files to the device itself. If windows tries to delete a locked file, you will receive an error. Browse through the manual of your device or the settings on the device itself and see if there's a lock or protection or USB mode somewhere.
Because you're getting the "cannot read from source or disk" error, I am strongly geared towards #1. Get yourself a new cable and see if that doesn't solve the problem.
Try to download" Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Most PMP's come with a format option in the settings menu. Back up any important files (if any) and format your player. This usually fixes most hard drive related problems.
A CRC error (Cyclic Redundancy Check) is a data corruption error. This basically means that the data read from the media did not match what was expected to be read by the software. I would say that it is most likely that the source media that you are copying/reading from is corrupted. It is also possible that the destination media that you are copying to could be the source of the problem. If it is a hard drive try running scan disk or other disk repair software, if it is a CD - clean or replace the CD.
David Millier
Advance Camera Repair
