Question about Reebok Exercise & Fitness
I have Reebok treadmill intermix acoustic. When it runs, the machine does not run smoothly, and it's speed shows lower or higher number for a few seconds.
SOURCE: Need a Reebok treadmill repairman.
I can fix it for you. Just post it to me in London. Hope this was of help!
Posted on Mar 02, 2009
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Posted on Sep 24, 2010
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
I need a manual for nordic trac intermix acoustic 2.0 tread mill
Do you know how to charge this model? I bought one off craigslist and it did not come with a charger.
Mar 23, 2013 | FreeMotion Intermix Acoustics 2.0 Console....
Reebok i run
RUN the software calibration for troubleshooting and fix it.
God bless you
follow the steps.
he Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 08, 2013 | Reebok treadmill i-run pure
Reebok 8100 es wont go any faster then .4mph
Please adjust the speed sensor, see the diagram, test it for open or faulty, clean it, and tight the plug very well.
However you must RUN the software calibration for easy diagnose, and troubleshooting and fix it. Go under HOOD motor, and follow the steps .
God bless you
Dec 03, 2012 | Exercise & Fitness
I have a Reebok Treadmill which operates only intermittently. I read Ernesto Cuadra's advice to anothe customer with a similar problem but the reed sensor is OK. What else can I try? How do I RUN
go under the HOOD cover from motor, read carefully the steps and proceed. In another models appear in your instr. manual if do not have instr. manual download:
www.fitness.manualsonline.com this is for diagnostic, troubleshooting, and fix it.
you must do the following: a) speed sensor see the diagram clean it ang tight b) tight the ribbon cable for KEYPADS C) TIGHT the plug from display board vs lower board see the block diagram.
God bless you
Sep 22, 2012 | Reebok Exercise & Fitness
Mar 07, 2010 | Reebok Exercise & Fitness
I have a 6 year old Reebok RX5000. At speeds
They walkbelt is most likely worn out causing too much friction overheating the motor.
Jan 15, 2010 | Exercise & Fitness
Exercise & Fitness Logo
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
