Good day. For you to be able to connect or detect a wifi you need to make sure of this things:
1. Check if wireless switch is on, which is usually located on the top part of your keyboard or at the side
2. check if the wireless network is present
> Go to Start
> go to control panel
> device manager
> Click Network Adapter ( check if a wireless adapter is present )
Note: if you see a red x on the wireless adapter you need to right click and enable the device
if you a yellow ! mark you need to reinstall the driver or software that came with your
notebook to make the wireless working
3. Make sure that if you have a firewall that it should not block the wifi connection
Hope this information will resolve your concern. Have a great day
Checked the device manager
go to network adapters
- make sure there's no question mark or X mark or even exclamation point on that tab -
- Fn and F5 - press and hold ( make sure the current status is on )
make sure the wirelss switch is on probably it must have green or white light
- update the drivers
