Unable to connect wireless A/V sender,model # VT46A VR because there is no output available on TV
4 Suggested Answers
SOURCE: WIRELESS LINK FOR SKY+ BOX
hi i need some help i got av sender with jack plugs. i want to connect with sky+ box but with av sender i got white,yellow,red but with the sky+box just addio cable not the vedio one so plz some one help me what i need to do thanks
Posted on Sep 30, 2008
dunnbiker
  • 8546 Answers
SOURCE: how to connect my kenwood vr-606 digital audio to
Your TV is NOT an audio source by itself. It's job is to make pretty visual stimulus for your eyes, not your ears. Everything IT hears comes from somewhere else like a DVD, BluRay, Cable Box, right?
Get the absolute best TV-related audio directly from the digital audio outputs of each source you're watching, not the TV.
Posted on Feb 20, 2010
smarthome2
  • 1114 Answers
SOURCE: On model # TC-P42C2 there
It has an Analog Audio output as well as a Digital Audio output. On the rear of the set at the Input block. Should say Digital out or Audio out. If you still have an issue,post a comment and I will help you further
Posted on Jan 16, 2011
My TV does not have audio output. will this system still work on my TV?
An audio output may be available if your TV is connected to a TV service provider box. . If you use a box than check to see if there is an audio output available. This will by-pass the TV.
Last resort there is probably a 2.5 mm connection for headsets some where on your TV. You can use a 2.5 mm to White and Red RCA connector cable to connect TV to stereo
This would be a simple stereo connection with out surround..
Nov 21, 2015 | Vizio VHT510-B Refurbished 5.1 Surround...
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
Optical hdmi
need to see the back of both units..
Jan 11, 2014 | Kenwood VR-716 6.1 Channels Receiver
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
Cannot get the receiver to connect to a newer
It would be the rare TV that originated anything approaching the sound quality of any other audio source in your home or could process digital multichannel audio anywhere near as well as the Kenwood. What model TV did you say this was? Its internal audio controls could also be part of the problem.
TV-related audio is best derived from as close to its source as possible. Your cable, satellite DVD, BD all have superior digital multichannel audio outputs. Why would you want to filter them through the TV first?
Those sources may also have HDMI which would be great for the TV; they also have standard RCA stereo outputs, each of which could be suitable to run to the TV's RCA inputs if you only want to watch news or weather with lo-fi sound.
Bottom line recommendation: BEST video to the TV; best audio to the Kenwood.
Mar 20, 2010 | Kenwood VR-507 Receiver
How to connect my kenwood vr-606 digital audio to my tv... i tried to connect digital audio cable from my tv digital audio output to kenwood vr-606 receiver digital audio in and it's not working.. what did...
Feb 19, 2010 | Kenwood VR-606 Receiver
Can I hook up my tv wirelessly to my home network?
Well I have, using those 2.4GHz AV Video/Audio Senders/Receivers, and as long as the PC you wish to watch has Composite Video OUT, then you can connect the "Sender" to the Video & Audio OUT, this in turn is "Transmitted" to the Receiver, that OUTPUTS again composite Video & Audio to the TV's Composite Video IN and AV IN. Yellow Video & Red & White are Audio IN. Works a treat.
Feb 15, 2010 | Toshiba 32A33 32" TV
How to connect my wireless headphone to a Panasonic LCD TV, there is only a single earphone jack mine has got 2 plugs
That's a new one, 2 plugs would indicate seperate audio ( right and left ) or 4 . Try this go to RadioShack and buy a Y that you can plug both plugs into and then plug the single plug into the TV jack. Look at the plugs on the headphone sender do the plugs have a single band or double? If single use above solution, if double just plug 1 plug in.Good Luck.
Sep 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
New computer (Vista) does not connect to internet. We have vonage VWR-VR D-link router and SBC Yahoo.
If you want this computer to connect wrielessly, go to Control Panel > Network and Sharing Center and click on Connect to Network. Select your router's signal from the list and click on Connect. It might require you to enter a network key. If you don't know your network key, call your ISP.
Apr 18, 2009 | D-Link Vonage-enabled Wireless Router...
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
