Question about ASUS Computers & Internet
How do I stop my laptop A3A from the screen going blank and loud music . I have to press any key to stop it and return to the programme I`m on. In 30 to 40 minutes this could happen 2 or 3 times Ann Dargie
  • 1,498 Answers
Hi Ann,
Laptops have options to prolong battery life that can sometimes be a bit tedious. No problem, to change the settings though.
Do this:
  • Click START
  • Click Control Panel
  • Double-Click Display
  • Click on the Screen Saver Tab
  • In the Monitor Power box Click the Power Button
  • Under the Power Schemes Tab, in the Power Schemes box, Click the Power Schemes drop down menu.
  • Click on 'Always On'
  • At the bottom, Click on OK
Keep in mind, after doing this, the conservation of battery power is no longer automatic. It's just as easy to change back, if necessary.
Any problems, additional questions click on the ASK button.
Posted on Aug 15, 2008
How do I set screen rotation
Simply hold down Control + Alt and then select the arrow key for which way you want your laptop or PC screen to face. Your monitor will then go briefly go blank and will return in a few seconds facing a different orientation. To restore this back to the traditional settings, press Control + Alt + the up arrow.11 Nov 2014
How to rotate a laptop or PC screen ' Alphr
www.alphr.com/features/.../how-to-rotate-a-laptop-or-pc-screen-flip-your-display-sidew... https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+do+I+set+screen+rotation+pc+laptop
Nov 29, 2016 | Computers & Internet
My screen goes blank after all disk top come up can you help i have a travelmat 2300 acer lap top
Looks like an issue with either display or system is overheating. Please try the below steps.
1. Shut down the computer
2. Keep on tapping F8 key as us press the Power button to turn on the computer.
3. Choose safe mode using the arrow keys on the keyboard and hit Enter Key
4. Stay on the safe mode to see if the screen is going blank, if not
5. A system restore should help to fix the issue. Let me know!
Thanks!
Anil.B.R
Oct 02, 2013 | Acer TravelMate Computers & Internet
Laptop screen is black
There are a couple of reasons that a laptop screen could blank our. The first is that many laptops have the ability to output video to an external monitor or projector, such as for video presentations. In order to save battery life, there is a function key combination that can be used to blank the laptop screen. Most laptops have these "functions" on the F1-F12 keys in blue and there is an "fn" key that must be used with them to activate the function. Look for a key that has a blue "square" with vertical lines on either side of it. This is the Monitor function key. Press and hole the "fn" key, then press the Monitor function key. See if the screen returns. A corrupted video driver could also be the problem. Do you have any display when booting up? If so, try using the F8 key to get to SAFE Mode. If you have a display there, check and see if there are any problems with the video driver, or just reload the driver. The third possibility is the the LCD's backlighting source may have failed. IF this is the case, you probably have an older laptop and replacement is usually cheaper and more cost effective than repair.
Jan 09, 2012 | Acer Computers & Internet
My e525 laptop starts up, and after the big "e" logo the screen goes blank.* Whenever I press a key there's a loud beep. How do I fix this? *As far as I can tell the screen is blank, but it's...
Try this... 1. Remove the battery 2. Remove the memory for about 5 minutes 3. Re-insert the memory 4. Press ESC for about 3 minutes while putting the power adapter. 5. Then turn on without battery.
Mar 11, 2011 | Acer eMachines 520-2890 Notebook
Screen not working
It could be the 'back light' is burned out.
Or
Press Fn and F5 simultaneously to make sure the display
priority is not set for the built-in screen.
Or
Press the 'brightness up' key a few times.
Display problems
Here are some typical display problems and their solutions:
The screen is blank.
Display Auto Off may have gone into effect. Press any key to
activate the screen.
You may have activated the instant password feature by pressing
Fn and F1 simultaneously. If you have registered a password, press
any key, type the password and press Enter. If no password is
registered, press any key. The screen reactivates and allows you to
continue working.
If you are using the built-in screen, make sure the display priority is
not set for an external monitor. To do this, press Fn and F5
simultaneously (once). If this does not correct the problem, press Fn
and F5 simultaneously again to return the display priority to its
previous setting.
HINT: Holding the Fn key and pressing the F5 key several times will
advance you through the display options.
If you are using an external monitor:
❖ Check that the monitor is turned on.
❖ Check that the monitor’s power cord/cable is firmly plugged in.
-- Try adjusting the contrast and brightness controls on the
external monitor
Aug 07, 2009 | Toshiba Satellite L305-S5907 Laptop
Hi i have got an acer extena 2300 laptop
when yo u power up the computer press F8 key then enter in safe mode.
Then go to start menu then run then type in run "chkdsk /r"
then press "y"
then resatrt it then it fixc error on harddisk.
Also try enable vga mode.
Check disply property screen resolution to 1024*768
Jun 23, 2009 | Computers & Internet
Black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Dec 30, 2008 | Acer Aspire 5100 Notebook
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
ACER apire 5050 screen keeps going blank/freezing
Hold down the "Fn" Key and press the "F4" Key, wait a min, press the Enter key on the keyboard... Do this when it happens, the problem is the ribbon cable in the laptop that goes to the screen is loose, If you want to fix permanently, send in for repair to Acer if under warranty.
Dec 17, 2008 | Acer Aspire 5050-3242 Notebook
R52 laptop screen stays blank
Try removing the battery and starting up just on power supply. May be a bad battery. If that doesn't work let me know.
Jun 06, 2008 | IBM ThinkPad R52 Notebook
Computers & Internet Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
