Question about Refrigerators
Can't find the manual. How much clearance behind unit, how far away from wall should it be. Thanks. It's a wine cooler
    Sergeant:
    Champion:
  • 257 Answers
All the way. Unless there are walls on either side and lid on top the air circulation should be fine.
Posted on May 22, 2011
What is my clearance regulations for
Hello Donna;
My name is Peter. I am a retired field service refrigeration technician.
The critical clearance, especially with under the counter units is in the back. You need extra space between the back wall and the heat coming off the compressor. I like to see 3" minimum. The more the better. If you are not getting sufficient air flow in the back then, your cooling condenser coil fan will constantly run in a effort to dissipate the heat.
Most manufactures recommend 1-1/4" minimum on the sides.
Nov 06, 2014 | Soleus JC-128 Wine Cooler
What is a freestanding wine cooler?
Freestanding wine cooler designed to stand alone without been attached to the wall. Freestanding wine cooler includes a front ventilation system which channels the heat forward away from the unit.
Aug 14, 2012 | Furniture
I have a e4 code on my wine cooler
I am sorry to hear regarding the trouble. This is a common problem on this unit. E4 refers to a faulty control board failure. Unplug the unit for few minutes, say 15 minutes and then turn it on. If this would not reset the error code, the only solution is to replace the board.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | Danby DWC283BLS Wine Cooler
The Danby wine cooler Model #DWC440BL-3 runs continously and is not cooling. There is a gurging sound from the compressor or the unit.
Sounds like the unit may have lost the refrigeration charge and or there is a problem with the compressor. Check your warranty depending how long you have own the unit it may be covered.
A manual can be downloaded from the following site.
http://www.retrevo.com/support/Danby-DWC283-Refrigerators-manual/id/886ag725/t/2/
Jim...if this information helped you please leave a comment...Thanks!
Feb 13, 2011 | Danby DWC283BLS Wine Cooler
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Power Consumption - Magic Chef Wine Cooler
The unit will draw between 6 and 12 amps on start up and running it should use less than 1.6 amps. The start up amps will increase with age. Funny how that works the same for people as it does for machines. I hope this will FixYa. Please dont forget to rate. Mike
Sep 23, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
Clearance??
hi you need at least 3 inchs clearance from the back ribs to the wall for good ventilation if there is no ventilation back there you will need to do 1 if to whole room is hot then you can install a fan that will cool down the heat from ribs good luck
Dec 20, 2005 | Kenmore 13485 Wine Cooler
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
