Question about LG DLG2532 Gas Dryer
I HAVE A LG DLG2532W GAS DRYER. IT WILL NOT DRY. I HAVE TAKEN IT APART AND CAN SEE THE HEATING ELAMENT HEATING UP. CAN U HELP
    President:
  • 3,074 Answers
Safety First, Unplug Dryer. There are two thermostats in the dryer. They are on the exhaust tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button.pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port. hope this helped Tim
Posted on May 22, 2011
  • pocowok Sep 13, 2011
    I would measure the resistance of each thermostat to see if it is open. Also inspect the ignitor's ceramic (dark grey in spiral pattern) crack due to aging. In my case, the ignitor was bracken and the part number is 5318EL3001A. You can also find free service manual by online search. You will need to follow the procedure to get at the front bottom below the drum. Jack
DLG2532W dryer not heating up. check filter light is on, but all filters are cleaned.
We have the same dryer and the check filter light always comes on at power up but goes off when starting. Is yours still not heating? as I see you question is a little old now. let us know.
Tim
Jul 05, 2010 | LG DLG2532 Gas Dryer
Model DLG2532W no heat, lint not an issue, circuit breakers OK, gas service OK. What could be the issue?
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 14, 2010 | LG Dryers
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
Not getting hot to dry clothes. Blower and tumbling working. Gas dryer. What is easiest way to access parts?
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 18, 2009 | Whirlpool GGW9868K Gas Dryer
No heat and the timer won't turn the dryer off
The timer runs thew the heat cycle with no heat it will run forever the heat runs thew the timer and thew thermstats and thermal fuses be for going to the heat elament check for 220volts at the heater if the heater has 220volts to it and not heating the elament is bad
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
LG DRYER DLG2532W GAS
Dryer doesn't get hot. Replaced all the sensors and still it doesn't get hot. Doesn't get hot in any mode. All vents are clear. I'm thinking that maybe there may not gas getting ignited, but I know nothing about gas stuff and am not sure if thats the problem. Any ideas of what I should be looking at next?
May 15, 2008 | LG DLG2532 Gas Dryer
DLG2532W - LG Gas Dryer - Not spinning/working
COULD BE A DOOR SWITCH A THERMAL FUSE A CONTROL BOARD OR A MOTOR
YOU'LL PROBOBLY NEED TO CALL FOR SERVICE
Feb 22, 2008 | Dryers
LG DLG2532W Gas dryer problem
dryer working and heating properly, when cycle complete all my clothes smell like gas though. Any suggestion
Nov 11, 2007 | LG DLE2532W Electric Dryer
HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
LG DLG2532 Gas Dryer Logo
401 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
