Question about Acer (KV.16X04.007) DVD Drive
I reformatted my system sometimes ago then i lost the dvd multi dl drive ,now have reformatted it back to the way it was before,so want to re install the dvd super multi dl drive back. thanks
  • Acer Master
  • 27,725 Answers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 22, 2011
  • Brian Sullivan
    Brian Sullivan May 22, 2011
    you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Is the 'DVD-Super Multi DL Drive' on the Acer 5742 Aspire basically a DVD rewriter, or does it just play DVD's?
This Super-Multi Drive will write to dual layer DVDs (DVD+R DL or DVD-R DL) at a 4x speed. The full specs of the Acer 5742 are available here: http://support.acer.com/acerpanam/notebook/2010/Acer/Aspire/Aspire5742/Aspire5742sp2.shtml .
You should be able to place a dual layer dvd in the drive and have it recognized. Windows may ask you if you want to format the disc.
I hope this helps.
Oct 08, 2011 | Acer Aspire 5742Z-4200 Notebook
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
In lost the installation software to my LG portable super multi drive. Model # GP08NU20. Can I download the installation software?
In lost the installation software Problem with the LG GP08NU20 DVD±RW Burner In lost the installation software to my LG portable super multi drive. Model # GP08NU20. Can I download the installation software?
Jan 24, 2011 | LG GP08NU20 DVD±RW Burner
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
I l lost the aspire 5738DG dvd super-multi dl driver
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
Dec 16, 2010 | Acer (KV.16X04.007) DVD Drive
I lost the aspire dvd super-multi dl driver and can not run the device. how can i get it? tks. victor
hey if u find the driver thn do mail the link or website to me at girishdiam@gmail.com
THANX
Girish
Oct 23, 2009 | Acer (KV.16X04.007) DVD Drive
I lost the drivers what can i do?
well you really don't need drivers for xp+ systems. it should automatically be recognized. you just have to get cd/dvd burning software like Nero.
according to this site that drive won't be recognized by vista with out a firmware update
http://www.cdfreaks.com/review/13311-LG-GSA-H42N-Super-Multi-DVD-Writer-Review/
Oct 13, 2009 | LG GSA-H42N 18x DVD RW DL IDE Drive...
LG GSA-E60L doesn't work...
Disc drive has nothing with drivers it works in almost any operating system...check the power and data cables
Feb 03, 2009 | LG SecurDisc 20x External Double-Layer DVD...
DRIVER FOR LG MULTI SUPER DVD BLACK
Start-Control pannel-System-Hardware tab(I don't know how it appears in english, bcause I have a Spanish O.S)
Then you will se a list of your hardware.
Look for DVD-CD drives and double clik to see if a driver is installed and corresponds with your hardware.
You have few possibilities:
1) an exclamation mark appears near the drive: this means that the driver was not properly installed: In that case double click and sear for a new driver
2) You have a driver that doesn't correspond to your harware:
Do the same as 1)
2) The drive installed is the correct one: The problem can be a hardware one.Note the exact name of the driver and the version and go to LG site and look for a new one
3) No DVD/CD drive appears in the list: Go to Start_control pannel_ add hardware and let windows search for your DVD and install the apropiate driver.Stay connected to Internet to let the system search on MS .
Hope that will help
Sep 08, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Acer (KV.16X04.007) DVD Drive Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
