Question about Sony Computers & Internet
Every time I start phtoshop cs5 I get the message that the display driver encountered problems and has temporarily disabled GPU enhancements.
  • 93 Answers
Do what PS tells you. One of three things is happening:
1. You video card needs a software update
2. Your video card is just not good enough and you need a new, better one.
or
3. PS is malfunctioning. A re-install or a call to PS tech support may or may not be in order.
Posted on May 22, 2011
Slow
look in administrator options
Feb 08, 2012 | Trust Slimline Design TB5300 (15356)
Can i add 2 graphics card in asus P5G41C-M LX ? now i have nvidia GTS 450 graphics card.. plz help.....
Hello there,
*********** board has an Integrated Intel GMA X4500 graphics, maximum shared memory of 1G, it should be automatically disabled if the pcie slot detects a video card but some mother board embedded gpu runs with the pcie card unless disabled in the bios.
Do you have plans on running a SLI (Scalable Link Interface) linking two or more gpu to produce a single output on *********** board. why SLI? because you already hae a GTS 450 GPU but you cant do this configuration because *********** board has a single pcie slot.
If you have plans on running a pci gpu with your GTS 450 it should, but if you encounter any problem try manually assigning IRQ's and resources through the BIOS? I don't have this specific board.
Hopefully this information helps.
Thanks you for using FixYa.
Sep 18, 2011 | Computers & Internet
My asus desktop pc shut down after it has started.
The most common reason for this is that there is an issue with your GPU/video card. Typically it's a problem with the driver. Try loading windows in safe mode and update the driver. If you are using the latest driver rollback the driver to a previous version and restart windows in normal mode.
To update the video driver you can go to http://drivers.downloadatoz.com/1799,everex-explora-rs2800-vga-video-driver/
Safe mode can be accessed by pressing F8 on the keyboard when the manufacturers logo appears on the screen when you restart. When windows is loaded, go to the control panel in the start menu, select System and Security and open the Device Manager. Select the display adaptor to find your GPU and right click, click properties select the driver tab in the properties menu and click the rollback driver button or and follow the prompts.
If updating or rolling back the driver doesn't work, it's most likely a GPU failure. If you are using the integrated video, you can purchase an AGP compatible video card and install it and disable the on-board video in the device manager. If you have a AGP video card installed, you can check to make sure the card is properly connected and seated securely in the AGP slot and if it's still not working properly, it may be time to find a replacement.
Aug 21, 2011 | Everex eXplora RS2800 PC Desktop
Photoshop cs5 opens an images then immediately states that it has encountered an error and closes. does this with all images. have uninstalled and reinstalled on several occasion but same issue every...
I think your Photoshop version is not registered, so installing on every system that is connected to the internet encounter you with this message.
I recommend you to reinstall your OS and then Install your Photoshop Offline.
Apr 15, 2011 | Adobe Photoshop CS for PC
I need a serial number of adobe phtoshop CS5
Try any one of the below serial no: and rate to me for your vailable votes.
SN]: 1325-0621-9125-0765-3648-0614
[SN]: 1325-0365-5929-6118-8817-8422
[SN]: 1325-0150-1163-7532-1626-3430
[SN]: 1325-0178-1927-9019-0123-2254
[SN]: 1325-0702-3693-1544-9166-3515
[SN]: 1325-0549-2240-0071-3409-1342
[SN]:1325-1558-5864-4422-1094-1126
[SN]:1325-1958-5864-4422-1094-1178
Thanks in advance...
Robin
Jan 08, 2011 | Computers & Internet
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
9800M GTS gpu instability in gateway p-7805u fx laptop....
Maybe a little late of a response, however... Ive had the p-7805u for quite a while. I had the same problem which I noticed that was triggered specially by old games rather than demanding games like Crysis. In fact, the computer never gave me a problem on the most demanding gpu applications, but crashed within minutes in games like Warcraft III. The screen showed artifacts, crashed and then recovered giving me the "driver has recovered" message, and ultimately and almost always hard froze after a couple minutes. I was getting really frustraded, even got an rma for warranty service, but didnt send it in because i couldnt survive without a computer at the time being.
I started monitoring my gpu clocks. Almost all gpu's, being more dramatic in mobiles, lower their clocks when they are idling. I finally noticed that the computer started artifacting and crashing when the clocks lowered for idling and lower energy consumption purposes. Simple solution: download desktop drivers from www.latopvideo2go.com , any in the 19x.xx branch, and use their modified inf so that you can install it in your laptop. In the nvidia control panel go to 3d settings and under global change "Power management mode" to "prefer maximum performance". This doesnt allow the gpu to lower its clocks, solves the problem permanently =). Ive run crash free for months, and battery life is only lowered by maybe 10 minutes, which you can always prevent by changing the setting when you plan to go on battery.
Jul 21, 2009 | Gateway P-7807u Notebook
Estrange characters appears in my tecra m4 645 nvidia
The video card has unseated or is fried due to overheating. The typical repair is to replace the entire motherboard which will cost about US$600 from a technician. The graphics chip GPU is soldered onto the motehrboard. I ahve heard some people cooking the GPU to reflow the solder if it is an unseated GPU chip that came loose but I have not tried this myself. This is a common problem of Tecra M4's and I have been through this problem 4 times in the past 4 years, each with expensive motherboard replacements.
Apr 10, 2009 | Toshiba Tecra M4-S435 Tablet PC
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
55 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
