Question about Pentair Whisperflo 1 12 Hp Pool Pump Wf26 011773 ()
Have a pentair 1 HP whisperflow pool pump. It makes a loud high pitch sound when turned on. Sometimes when first turned on it won't but quickly will begin making the loud high pitch sound. Almost like it is starving for water. It also spirts water from the gasket seal plate when first turned on but fixed that problem I think. I took pump face off and noticed that the O ring that fits against the pot fit loosely but wasn't sure it that was normal.
Are you sure that you have it wired the right way. it has a setting for 220 or 110 the pump will run if it is not wired correctly however it will be varey ******* the brushes inside the motor resulting in a loss of efficiency
Posted on May 27, 2012
SOURCE: pentair whisperflo pool pump motor replacement
No there is a cover on the other side of the motor thet comes off and with a 9/16 wrench holding the shaft - spin the impeller off
Posted on Jun 28, 2009
StepehnD
  • 78 Answers
SOURCE: wirng connecions for 110v pentair pool motor???
Next, as a suggestion. Purchase an Emerson Pool motor. The electrical connection is the same for 110/220 volts. All you have to do is move the switch by the electrical connections and select 110 or 220 volts. They usually come preset on 220 but I would check anyway. Also, don't forget the ground wire (green) and also connecting the bonding wire on the outside of the motor near the plastic cover for wiring. If you don't have bonding I would get it real soon! Hope this helps..
Posted on Jun 06, 2010
jharwell668
  • 640 Answers
SOURCE: My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
Posted on Jul 20, 2010
john224
  • 1378 Answers
SOURCE: I have a 2HP Pentair Whisperflow pump that has
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 26, 2010
jharwell668
  • 640 Answers
SOURCE: I have a Pentair letro legend platinum pool
You DO need a booster pump to power these automatic pool cleaners. It will not work without one.
Posted on May 11, 2011
Have a 2 hp 2 speed Pentair whisperflow pool pump, it seems to only operate in low speed.. is about 5 years old..checked for obstruction at impeller but seems fine..any suggestions much appreciated..
check for power on high with a meter, or bring it to your local pool pump motor repair guy with free testing. TAKE NOTE on where the wires are hooked up !! they must go back the way they came off !!!
Sep 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Whisperflow pump making loud squealing noise
The noise is likely either the seal or a bearing in that order. If you are mechanically capable of working on the pump yourself then you can purchase a seal and gaskets at a pool supply store. If the bearings are bad then the motor needs to be replaced. In some cases a bearing can be replaced but usually it is more work than it is worth.
Aug 09, 2011 | Pentair 1 hp WhisperFlo InGround Pool Pump...
I do have inground pool 16 *32 10 feet deep at one end and 4 feet at front, The pump did not start at all when i started it. Since the pump is an old pump above 15 years old I decided I would buy a new...
I'd suggest the 1.5 HP Hayward Super Pump, model SP2610X15. It's layout makes fitting it into the footprint of the Jacuzzi easier since it's ports roughly line up and are smaller in spread than the jacuzzi. Any pump will require some monor replumbing; the Haywards should be the least intrusive.
Another good choice would be the Pentair Whisperflow in a 1.5HP with or without the variable spped features.
John
May 01, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out.  There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
Dec 28, 2008 | Pentair 1.0 Hp Whisperflo Pump
Pentair Whisperflo 1 12 Hp Pool Pump Wf26 011773 () Logo
217 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
