Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
Have never used the lawnmower and the pull cord seems locked or stuck. I can't pull it at all. Is there a button or lever that needs to be pushed before intial use of machine?
  • 843 Answers
There is a brake lever that stops the motor and blade when it is released. This is usually parallel to the handle and would normally be squeezed against the handle when you operate the mower. When released, it is a safety mechanism to immediately stop the spinning blade. You have to squeeze that lever in order to start or run the mower. You can see that lever in the image at the top of your question. Good luck, Al K
Posted on May 22, 2011
I have a Snapper self-propelled lawnmower and The starter cord will not pull out to get it started. What do I do next?
Hi Patricia,
There is probably a safety lever that has to be pulled back toward the handle in order to release the flywheel. (This lever is on the top side of handle.) Once you have it firmly against the handle it should start. To stop the mower, simply release the lever. There may also be a 2nd lever to engage the self-propelled (located under the handle). It may be difficult to start with this one pulled.
Jim
May 23, 2016 | Briggs & Stratton Garden
Starter cord on lawnmower will not pull out
Hi Mary. You will need to remove the starter box on your mower. The coil box may be rusty or the pully may need fixing. Try using some oil spray and see if the pully now works. If the starter coil is clean the mower may be ceased.
Jul 27, 2013 | Garden
I have an Olympia Progress manual typewriter. It seems to be in good working order, well oiled and good action in the keys, except the carriage won't advance when I type. I don't believe the...
try typing with a little pressure on the carriage (push with right hand to the left) if it work like that then the carriage pull cord may be broken
Apr 23, 2013 | Office Equipment & Supplies
New unused Craftsman Push Mower will not start
May be bad battery ? Have you try another battery ?
Apr 11, 2013 | Garden
My 2002 vw cabrio door locks stuck in locked position even though the lock button by window goes up and down when you push lock and unlock button on door. The door is locked when you pull handle but the...
If you would like to fix this yourself, you will be needing to pull the door panel off that side and finding the problem inside the door, but, before you do, here's what you are looking for:
The door latch is fastened to the door jamb with screws.
There are several wire-like levers that come to the door latch and tell it whether to lock or not, to open or not, etc.
The wire type levers come from the two handles, ( inside and out,) and the locking mechanisms, inside and out.
One of your has broken or come apart.
Maybe a bushing has failed at the end of one of the levers.
Be blessed.
Jan 23, 2013 | 2000 Volkswagen Cabrio
Pull cord on my lawnmower is inoperative
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Dec 07, 2012 | Craftsman 55 Torque 158cc 22" Push Lawn...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
I have a '04 rio and the driver side door is stuck shut, when the manual lock pin is pulled up, it snaps back down like its on a rubber band.
JEB, Homestead Florida
Total credit to rfbqwerty
Have 2003 Kia Rio 1.6, door shut, locking pin springs back down, I followed rfbqwerty istructions to the Penny and it worked in about 20 minutes I was able to open the door. The restst is a POC, thanks a million!!!
Option found in Google 6/16/2012
rfbqwerty
03-28-2006, 06:22 AM
Easy method to open a stuck Kia Rio door. Full credit to 'fastkia' for explaining how to open a stuck lock but after opening my lock by his method I found an easier way to do the job. You need a piece of straight wire (clothes hanger is good) and make a 3/4 inch square bend on one end. Wind down the window & push a tapered (plastic) wedge between the glass and the inside rubber to get a gap to work through. Poke the wire down beside the glass and pull up on the lever that is operated by the outside door handle. This is not the wire from the door handle but is the lever the wire connects to in the lock. While the lever is held up by your hook you can now pull up the locking button. Remove the wire from the door and everything works and it can be opened and closed as often as you like but don't press the button or use the key lock or it will be stuck again. The lever is normally held up by a small spring that has a sharp bend at one end and the spring will ALWAYS break at this bend. I used the same spring with a 'new' loop made from a section of paper clip to replace the old loop. Better than the original. No cost and it took less than 30 minutes
Mar 09, 2010 | 2002 Kia Rio
Can't start it up - no instructions
Steps
  1. Make sure you have enough motor oil in your mower. Usually there is a cap on top of the mower body, smaller than the gas cap, that says "oil" or something similar. The cap will probably have an oil gauge attached, so check the oil as you would in a car, that is, judge the level of oil on the gauge against the depth of the reservoir (the length of the gauge).
  2. Make sure you have enough gasoline. There should be a clearly labeled cap on the gas tank. If you open it, you should be able to look down into the tank and see the approximate level. Add more (preferably using a funnel) if needed.
  3. Locate the prime button, usually red or black, a squishy button somewhere on the mower's body. Push it between 3 and 8 times in order to force the gasoline into the lines.
  4. You may need to pull and hold a starting lever (a safety feature), or the lawnmower will not start no matter what you do.
  5. Brace your arm holding the starting lever, and pull upward on the pull cord, which you should find on top of the mower body. You may have to do this several times before the motor starts up.
  6. If you are still unable to get your mower started, try the lawnmower inspection and troubleshooting steps at http://www.wikihow.com/Repair-a-Lawnmower.
http://www.wikihow.com/Start-a-Push-Lawn-Mower
May 11, 2009 | Garden
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
225 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
