Question about HP LaserJet 1020 Printer
Printing graphics Hi, When printing graphics, I get vertical bar at edge of paper. The bar does not appear on text only print out.
  • almondo Aug 15, 2008
    The vertical bar does not appear on print preview. The paper is fitted properly.
    The bar appears on the print margin area. It looks like some sort of right border.
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    Does it show on a print preview? is the paper lined up absolutely snug in the paper feed slot?
Their is a newer driver from the www.hp.com site (click on drivers) then type "laserjet 1020" and you should see a operating system (xp-2000-vista) button to click on
under the xp drivers
I downloaded a newer driver that has the fix for this problem
Posted on Aug 18, 2008
  • 876 Answers
Is it outside the normal printing area? It seems strange-Could there be something stuck in the machine over there? or an ink blob on the paper roller?
Posted on Aug 15, 2008
I am getting a 5mm dark bar on the lead edge of a print job
try drum refresh and developer refresh... make sure your firmware is current... if possible reset your print card... physically and software wise... make sure that the guides on your paper trays are a good fit... change the default paper tray for print jobs and see if that helps... if it does... then its the tray... if not then call service...
Dec 12, 2009 | Canon imageRUNNER 2200
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
White vertical line in image printing
how can we take all fax sent and received print from hp 3050 printer.
Apr 01, 2009 | Epson Aculaser C1100 Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Vertical lines through my text and photos
Either clean the print head nozzles or select a higher print quality and turn off High Speed mode.
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
Bar codes appear solid back
I have problem with the same printer, the bar code is not printed, someone can help me?
Apr 09, 2008 | Zebra 105Se Thermal Printer
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
HP LaserJet 1020 Printer Logo
60 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
