Question about Canon PIXMA MP150 All-In-One InkJet Printer
Scanning on my PIXMA MP150
I have lost my directions and have something to scan. I have no idea how to do it. Is there a direction manual online that I can use or could you just tell me and I'll write it down. Thanks.
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
PIXMA MP150
See page 57.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 15, 2008
My PIXMA MP150 will not scan and keeps flashing on B any ideas???
if it will still print I have no idea but if not it probably means there is something wrong with your black cartridge - a lot of these printers need both cartridges working before they will even scan
Jun 10, 2015 | Canon PIXMA MP150 All-In-One InkJet...
There are no directions on how to use the scanner on the MX320 printer. How do I know if I have the right program and if I have how do I manage to scan?
Scanning Methods
You can select from the various scanning methods.
>If You Want to Edit or Print the Scanned images MP Navigator EX enables you to edit the scanned images, such as optimizing or trimming. You can also start application software from MP Navigator EX to edit or print the scanned images. For detailed operations of MP Navigator EX, refer to the Scanning Guide on-screen manual. You can also use the Operation Panel to open MP Navigator EX as well as open it using the computer.
>If You Want to Scan Originals with Advanced Settings ScanGear enables you to scan originals with advanced settings such as the resolution. For detailed operations of ScanGear, refer to the Scanning Guide on-screen manual.
Besides the above-mentioned methods, you can use a TWAIN- or WIA- (Windows Vista and
Windows XP only) compliant application software and the Control Panel (Windows Vista and
Windows XP only) to scan originals with this machine. For detailed operations, refer to the
>Opening MP Navigator EX using the Operation Panel
>>(Macintosh only) Prepare your computer before scanning. This operation is not necessary for Mac OS X v.10.4.x.User's Guide on-screen manual.
>>Turn on the machine.
>>Load the original document on the Platen Glass or the ADF.
>>Press the SCAN button, then press the Color or Black button.
I found these directions from your Canon PIXMA MX310 User's Manual online (page 24). Other functions are available for reading.
To make sure you have got the correct program that you are using, uninstall all associated programs from your computer thru "Programs and Features" that can be found in Control Panel. Then, you may download your printer's drivers and softwares thru this LINK. Make sure to download the appropriate version for your Windows.
NOTE: Keep in mind that the drivers and softwares are limited to the manufacturer's release.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 23, 2011 | Canon PIXMA MX310 All-In-One Printer
How do you use the scanner?
Hi woolyj,
I'm not familiar with this model, but the manual should have this information. I've put direct links to the manual for both Windows and Mac below.
In Windows 7 and Windows XP, there is an included Scan utility. In Windows 7, click start and type scan into the search box. This will locate the scanning software. Choose file, new scan to start scanning. The process is similar in Windows XP.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
I cannot get my pixma mp150 all in one to scan when i press the scan button
Please check if your scanner is connected to the computer and both are turned on. For the scanner to work directly from the printer your ink levels need to be accurate (dont ask why) however, if you have MP Navigator and connected to a PC, then i suggest you use that. It will scan even with low, unknown or zero ink levels.
You can download MP Navigator from here
Oct 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I HAVE CANNON PIXMA MP150 LOST THE SOFTWARE THAT CAME WITH IT FOR PHOTOS AND PROJECTS I DID IN CRAFTING IT WAS SOMETHING CALLED SCAN GEAR WAS ONE I THINK?? BUT IT CAME ALREADY ON THE INSTALLATION DISC I...
The "Vista Home Premium Service Pack 2" disk that it is prompting you for came with your computer itself, not the printer. It's most likely labelled "Setup" or "restore" disk - just put it in the drive when prompted and you should be all set!
Oct 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon - Pixma MP150 printer/scanner won't scan in color.
may be you not installed the scanner application software if you have driver disk of printer choose the customs installation and select the scanning option menu and re install it the application.
Sep 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Scanning
it is problem setup scanning option
Jul 31, 2009 | Canon PIXMA MP150 All-In-One InkJet...
About serial key
Details Issue: Where is the serial number located?
Solution: Locate the serial number MP150
topFrame=findTop(this); Locate the Serial Number The serial number of the PIXMA MP150 is located inside the printer, as shown below.
  1. With the printer powered on, lift the scanning unit and pull the scanning unit support down into place.
  2. The serial number is attached to the back wall inside the printer.
    It starts with four letters (JCBA, JCBB, JCBC or JCBD) and ends with five numbers. Example: JCBA01234, etc.
.footergray { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: none; font-weight: bolder; } .footerblack { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: underline; font-weight: bolder; } © 2008 Canon U.S.A., Inc. All rights reserved. Duplication in whole or in part without permission is prohibited.
Jan 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E5 error code on canon pixma mp150
I had run into a similar problem with my all-in-one and had to use
http://www.irfanview.com/ (which is free) to scan with
Open irfanview and select File>Acquire Batch Scanning
Jan 09, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
174 people viewed this question
old marine
old marine
