Question about Dryers
I have a maytag neptue dc dryer & I need to know how to replace the belt
    President:
  • 3,074 Answers
Open the cabinet:
http://www.partselect.com/dryer+maytag-atlantis-open-cabinet+repair.htm
route the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Posted on May 22, 2011
How to replace an Dryer Drum Belt ?
check youtube for a lot of vids on this subject
Feb 14, 2018 | Maytag Performa PAV2200
I need a diagram of how the drum belt is installed on a maytag centennial dryer. Mine came off and I don't know how to put back on.
Hi c ellerts..
Here is the picture of the routing of your Maytag..
You can get this at the following wepage
Please take time to rate me thumbs up
http://www.expertappliance.com/dryerbeltconfiguration.html
Sep 12, 2011 | Maytag Dryers
My Neptue dryer wont dry unless I run it more than one cycle. model no. mdg5500awq. all lights work and seems to run fine it just wont dry the cloths unless I run it at least twice and jeans are three or...
Turn dryer on and go outside to the vent and check for a good amount of air coming out. If you do not have a good amount of air coming out, take the exhaust tubes apart and clean.
Jun 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dyer Model# pyg3360aww Serial# 10345972an the cylinder will not spin, took off top of dyer and the belts are broken. what do i do.
Remove the broken belts and take then with you to a local appliance parts store. Also write down the make, model & serial # of the unit to ensure the correct part can be found on the shelves, and ordered if not in stock. If you need assistance putting the belts back on, let us know.
If the unit is still under warranty, you can get Maytag at 1 (800) 344-1274 U.S. to pay for them too. If it is, you should call Maytag directly to get the free replacement parts. I found your owner's manual and it says any part on the dryer is guaranteed for 1 year. Here's the link below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/PY-1_Dryer_53-3650-3.pdf
May 18, 2010 | Maytag Dryers
Belt on maytag neptune dc dryer needs to be replaced. how do i replace it.
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). This being the case you need to look for screws you can find on the dryer2_bing.gif outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
May 02, 2010 | Maytag Dryers
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
No heat in dryer
check the ignitor, or the piliot lite depending on the age of the dryer, the ignitor is made of carbod and you have 1 screw that holds it in place make sure as to not touch the new one with your hands or anything for that matter vary fragile and if the acid from your skin gets on it will not work, if it has a standing piliot check to see if it is there if not it could be the thermocoupling
May 30, 2009 | Dryers
Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
Dryers Logo
143 people viewed this question
Top Dryers Experts
