Question about Nikon COOLPIX L20 Digital Camera
I am loosing group of pictures from my memory card without deleting them the problem appears to be related with the battery replacement. Everytime i replace a battery a bunch of pictures disappear. does anyone have a solution for this?
Some photos you take may be saved to the internal memory of yor camera, when you move your battery, those images can be lost. make sure you save your images on a SD card
Posted on May 22, 2011
How do I delete photos in the gallery on Samsung Galaxy tab 4?
To delete a single image, summon the image on the screen and touch the Trash icon that appears in the upper-right corner. Choose the Confirm Delete command. The image is gone.
Deleting a video isn't as easy as removing an image: You have to long-press the video thumbnail in an album. The long-press activates multiple-selection mode. For removing a video, however, just touch the Trash icon that appears in the upper-right corner of the screen. Choose the Confirm Delete command, and the video is gone.
You can't undelete an image or a video you've deleted. There's no way to recover such an image using available tools on the Galaxy Tab.
You can apply the Delete command to an entire swath of items in the gallery at once. To do so, you must know the secret, found below:
  1. Open the album (pile) you want to mess with.
  2. Long-press an image to select it. Instantly, you activate image-selection mode.
  1. Continue touching images and videos to select them.Or you can choose the Select All command.
  2. Perform an action on the group of images or videos.
To deselect items, touch them again. To deselect everything, touch the Done command.
The type of commands you can use on a group of items in an album depends on the group. Some commands, such as Delete and Share, can be performed on any old group. Other commands, such as the image rotation commands, work only with pictures, not with videos.
Apr 26, 2016 | Samsung 7 Galaxy Tab 4 8GB White
I cant use my cam the screen appear full card
Delete some pictures off of the memory card. If you don't have a memory card that's your problem. Your camera can only hold 1-10 pictures without a memory chip installed
Sep 21, 2012 | GE A830 Digital Camera
I have a san disk 2gb memory card for my nokia phone, i took my memory card out for the first time as i wanted to put the pictures from it onto my computer, everything worked fine, however when i put my...
you can not format your card without loosing data on it. The solution is to copy all the data to your computer, format the card (in your computer, still) and then copy the data back.
Hope this helps,
Lucas
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
Can you erase all pictures on your memory card at once, rather than one at a time?
Many cameras will allow you to "format" a memory card in the camera. Like formatting drives in a computer, this deletes all files from the disk. The command to do this may be buried a bit in the controls to prevent accidental activation.
You can also do a format or delete a large number of individual files from a removable memory card if you insert into a "card reader" connected to a computer. An example of an external reader is below:
These devices typically connect to the USB port on the Mac or PC. Be sure to purchase USB "High Speed" or version 2.0 (or greater) devices; USB "Full Speed" or version 1.0 devices are much slower than the newer 2.0 (and up) devices. Nearly all of these readers have the capability to write to cards, too. When connected to a computer, they will appear as a new drive. You can simply copy, move and delete individual files (or large groups of files) and "format" the memory card just as you would with any other drive inside your computer, without the need of a camera.
Please rate this reply if it was helpful. Good luck!
Aug 18, 2010 | Cameras
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
Everytime i try take a picture i get this "not enough memory,please delete some items" altho its a 2gb memory card
ur memory card is full..that is if ur having an sd card in ur mobile..if yes..format ur memory card. If no, jus delete all de images ,songs and videos that u have stored in your mobile..that will do the trick..ok
May 25, 2009 | Samsung J700 Cellular Phone
How do I down load pictures to computer from A345 without
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 21, 2009 | Fuji FinePix A345 Digital Camera
Can't playback pictures
Try formatting the memory card in your camera. Search the camera's menus to find the option that lets you do a "Full" or "Low Level" format, and NOT a "quick" format.
Feb 12, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Nikon COOLPIX L20 Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
