We have a Sharp Micro Component Stereo System XL-DK257N and it's been working fine for a year but suddenly it stop working. The stereo just keeps shutting off when you try to power it on. You would see the "POWER ON" and then it would just shut off by itself and would not stay on even for a minute. I've tried another outlet, tried resetting it using the manual that came with it but to no avail. I really love this system and I hate to just throw it in the garbage. Please help. Thanks! I reposted this because I have the same problem with the same model
  • joye2000 May 22, 2011
    How do I reset it?
  • 2,632 Answers
Welcome to Fixya. If you already reset the device and still shutting down. the problem of the system is the system board. It can be the fuse, the capacitor or transistor that is bad. You have an option not to throw away the device but to have it repair to a service center to replace the faulty part of the board
Thanks
Posted on May 22, 2011
  • Rofel Lantican
    Rofel Lantican May 22, 2011
    What i mean is power reset unplug the machine to drain the power on the system board. If still wont work you need to bring it to a service center. Please disconnect the device from the electrical outlet so that you can avoid further damage
Stereo turns on shuts off after few seconds
This is a bad power supply. You have to do some serious work at the component level of the unit to fix it.
Jan 22, 2014 | Sharp Electronics - Xldk257n - Xl-Dk257n...
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
I want to connect my XL-DK255 to my TV (Sanyo DP26671). Please help!!!!
http://www.manualowl.com/m/Sanyo/DP26671/Manual/211922
the only way to connect them is audio ...and you can either connect the Tv to the system ..(for better sound ) ..and in this case use the rca (left /right ) to rca (left right ) on the sharp ..if it supports..or ..use a double rca stereo cable ..with a jack 3.5 end ..and insert it in the audio input of teh sharp system ..
The signal from the Tv it will have to be taken from the audio out like in th epage 13 of the manual ..(it has a mono exit ..on rca probably ) and a left and right stereo one ..
If the sharp supports rca stereo in ...use it ..or ...just use the jack (3,5 stereo ) in ...and do not forget to select the proper channel ..
if the sharp system has a TV input channel for sound..on the receiver..use it ..and select the TV to playback the sound ..if it do not ..use the aux.. and selct the aux for control it ..
I do not believe you need to connect it in the other way cause it is not make any sense ..but the procedure is the same ..get audio signal from the system and insert into the audio in of the TV ..it is in the same place and also available mono and stereo ..You will have to select the input in the tv menu..
The cable you need for a stereo connection I think will look like thi s..
http://www.alibaba.com/product-gs/369945799/Factory_direct_supply_Adapter_Cable_jack.html
Jul 20, 2011 | Sharp XL-DK225 Shelf System
XL-MP60 Shelf System: stereo shuts down and reads protect...
Hello, the problem of you stereo appliances been shut down was as result of a mechanism jam of the system.
The way you could do this is to open the back cover of the appliances and check for the rubber attached to the motor of the appliances, also check and see if you can adjust the mechanism if it is a disorder manner, it require a careful approach.
This will require a skilled personnel to handle this
May 17, 2010 | Sharp XL-MP60 Shelf System
HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System: my jvc was working fine but all of a sudden it sto...
Hello
this could be a power fault, but first check the power plug if it is in contact with the power socket and if it is then you have to open the back cover of the system to check the fuses if blown resistor,capacitor and transistor with the use of a multimeter to check for back component and if bad replace faulty ones.
Then power on to confirm, if not on then take it to the manufacturer or a skilled personnel to handle it
May 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Car Stereo in 1999 Accord stopped working
take it to a pro dont waste your time
Jan 27, 2010 | 1999 Honda Accord
Sharp Micro Component System XL-ES50 won't turn on
my copies sharp mx 2700n how to go SP mode and i get eroor code h5.01
Dec 22, 2008 | Sharp XL-ES50 CD Shelf System
Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Sep 07, 2008 | Sharp XL-HP505 CD Shelf System
CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Apr 09, 2008 | Sharp XL-HP515 CD Shelf System
 Grubhead
Grubhead
