Question about Miele Novotronic W1918A Front Load Washer
The two lights to check outlet and inlet are flashing and the water will not drain away. I imagine that it's the pump or something. I've opened the little door down at the bottom left and I've cleaned the filter...there was a bit of hair or something but that hasn't fixed it. I can't find my instructions. First of all the problem only seemed to be the draining away but after playing around a bit the other light has also come on. It's a Miele Novotronic W502 and it's about 3 years old. Hasn't given me any problems until now.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
In the bottom of your machine the is a tray in the tray the is a float, if the machine leaks the float lifts and hits a switch activating the two light on the fascia. By tipping the machine you are emptying the tray thus allow it to work.Most likely cause is when you checked the drain pump the flap on the front was not angled down sufficiently or you unscrewed the filter to much and water backed up into the base. Put towel on floor and tip appliance and retest
Posted on May 24, 2011
    Problem Solver:
  • 5 Answers
I had the same problem with the 2 red lights flashing, which was fixed by emptying the float tray as above.
On further investigation I found that the door seal had rubbed on itself at the 6 o'clock position and had worn a small hole which was causing the water leak.
To replace or repair the Door Seal you will need to remove the front panel.
1. Turn power off and unplug machine after opening door.
2. Remove the front panel lower kick plate by inserting a thin ruler between the kick plate and front panel about 4 inches from each end and lever down until it releases.
3. Remove the 2 screws at the door lock switch on the front panel.
4. With the kick plate removed you will see 2 screws at each lower edge of the front panel, remove these 4 screws.
5. Remove the spring loaded band from around the edge of the door seal facing you and after that release the seal from the front panel and push in.
6. Remove the hex bolt from the 6 o'clock position just below the door seal on the front panel.
7. You should now be able to lower the front panel out of the locating pins and remove it.
8. With front panel removed you will be able to remove the tensioning band which holds the door seal in place around the drum by undoing the screw at the right hand side of the band at the 3 o'clock position. It is accessible from above with a long bladed screwdriver. Take note of how far it is tensioned on the thread of the screw and try not to undo it all the way or you may lose the nut on the band.
9. Once you have removed the band, slip the seal off the drum and slide the water outlet to the seal from the dispenser.
10. When you replace the seal do not do the tensioning band up too tightly or you will hear it squeak when you spin the drum in either direction.
11.Reassembly is the reverse of removal, taking care to put the door manual release strap through the inner slot in the front panel.
I repaired my door seal with Silicone Sealant and loose weave fabric tape after rubbing it clean with alcohol as i didn't want to pay $100 for a new seal from Miele.
Posted on Mar 13, 2013
Are the dishwashers supposed to drain completely away as there is water sitting under the filters?
There is a check valve on the pump outlet where the drain hose connects to the machine. It may have something holding it open.
Nov 06, 2014 | Dishwashers
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Fault F05 flashing
First of all remove the hose and drain off water then open the door . Once the drain pump outlet filters and the inlet filters are checked, check for free flow. If the cycle does not start check for power output from the controller on pump and motor. If not the board is a suspect.
Jan 23, 2013 | Washing Machines
Wd440 not spinning and flashing lights
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 27, 2012 | Hotpoint Washing Machines
How do you install a thermostat on a 2001 suburban?
  1. Standing in front of the vehicle it's on the left front side of engine kind of low.
  2. Be sure to get a gasket as well.
  3. Drain the cooling system.
  4. Loosen the air cleaner outlet duct clamps at the following locations:
    • Throttle body
    • Mass airflow/intake air temperature (MAF/IAT) sensor
  5. Remove the radiator inlet hose clip from the outlet duct.
  6. Remove the air cleaner outlet duct.
  7. Reposition the outlet hose clamp at the water pump.
  8. Remove the outlet hose from the water pump.
  9. Remove the water pump inlet bolts.
  10. Remove the water pump inlet and thermostat from the water pump. Water pump inlet/thermostat assembly location
To install:
  1. Install the thermostat and water pump inlet to the water pump.
  2. Install the water pump inlet bolts.
  3. Tighten the water pump inlet bolts to 11 ft. lbs. (15 Nm).
  4. Install the outlet hose to the water pump.
  5. Position the outlet hose clamp at the water pump. NOTE
    Important: Align the arrow at the throttle body end of the duct with the throttle body attaching stud.
  6. Install the air cleaner outlet duct.
  7. Install the radiator inlet hose clip to the outlet duct.
  8. Tighten the air cleaner outlet duct clamps at the following locations:
    • Throttle body
  9. Tighten the air cleaner outlet duct clamp screws to 62 inch lbs. (7 Nm).
  10. Fill the cooling system and check for leaks.
Read more: http://wiki.answers.com/Q/Where_is_the_thermostat_located_on_a_2001_chevy_suburban#ixzz1TvIO3kpD
Aug 03, 2011 | 2001 Chevrolet Suburban
Fisher & Paykel GW611 Excellence does not pump water out. All lights are on and when it is suppose to pump, you can hear the noise, but no water coming out of the hose!
It sounds like the drain pump or the diverter valve is restricted. Check to make sure that the drain hose is clear then disconnect power and lay the machine's front on a padded surface to access the drain pump and the diverter valve at the bottom of the tub. Remove the pump's inlet and outlet hoses then check and clear from any debris that may prevent water from draining out. Check the impeller for any damage or restriction.
Check the diverter valve for the same condition as the pump described above. T
he diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Jul 18, 2011 | Fisher and Paykel Fisher & Paykel Washer
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
Miele dw flashes 5 times, water is draining. Suspect filter/valve housing at end of water inlet line. Their is a wire running to this valv so I imagine whatever solenoid that tells the valve to open and...
which light is flashing? if the intake drain light is blinking and you dont hear the drain pump, it means water is not coming in. if the drain pump is running all the time, it means water has leaked into the bottom pan. behind the plastic toe kick, there is a panel that can be removed with two phillips head screws. It you can see water in there, you can dry it out, and try to run another cycle. if it runs fine, cut back on your detergent usage. if it leaks again within a cycle or two, you will need to locate the leak and repair.
Nov 18, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele Novotronic W1918A Front Load Washer Logo
432 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
