Question about Dryers
Have a 120 VAC whirpool gas dryer (Model LG9201W), have power to the gas unit (120 VAC). Have 27 VAC to the heating element, with no glow from the heating element. Is this why the solenoid are not opening causing the gas not to work??
    President:
  • 3,074 Answers
Http://www.applianceaid.com/gas_dryer.html#noheat
Posted on May 22, 2011
My gas dryer burner does not heat. The igniter does not glow even to permit the gas valve to turn on. Everything else works and checks out being good, such as the thermostats, igniter, flame sensor. ...
You could check the igniter by testing to see if 120 volts is at the wiring the igniter plugs into, if 120 vac at that plug the igniter is bad Also need to check THERMAL FUSE,in addation to thermostat,on electric dryers if thermal fuse is out it cuts circuit to motor, on many brand dryers if thermal fuse bad on GAS dryer it cuts circuit to igniter
Aug 12, 2011 | Dryers
Tip
Whirlpool or Kenmore Dryer Does Not Heat
Electric
First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
Gas
On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
Electric Dryers
NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
on Apr 17, 2010 | Dryers
My whirpool gas dryer model number wdg6200swq, wont heat up. the ignitor lights but no gas lights
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 02, 2011 | Whirlpool Dryers
Lost heat for my Dryer Whirpool LER3624JQO. Discovered heating element had a break in the coil. Bought new element at local appliance store, while I was there I had all 3 T-stats tested, everything tested...
heatman101
Feb 04, 2011 | Whirlpool LER3624JQ Electric Dryer
I have a whirpool dryer model ler4634pq. I will not heat. I had the heating element and replaced the theromstats on the element but it still does heat. I had the switch checked. I checked to make sure hose...
heatman101
Apr 13, 2010 | Whirlpool LER4634PQ Electric Dryer
My dryer doesnt heat all of a sudden. It runs but doesn't dry!
If this is a gas dryer, then you need to check the heating element and make sure that it is glowing, if it is glowing then there is a issue with the gas valve, if it is not glowing then there is a issue with the heating element. It is located in the back of the unit, you will need to remove the back cover
Jan 10, 2010 | GE Dryers
No dryer or washer control will start the unit running. appears no power...we checked for 240v at plug it ok...
Check the 240 vac again, but measure each leg to neutral while attempting to start the appliance. Each "leg" should measure approx. 120 VAC< (half of the total voltage) and should not change when the unit is started.I think you will find that the two 120 VAC legs will read OK until start up. If the voltage value on one leg drops to 60 VAC or less and the other leg increases by the same amount, Then there is a problem with the neutral wire or the connection between the ground of your appliances and earth ground. This is very common, particularly manufactured homes. Most dryers, for example, use 240 VAC to run the heating element, but also use 120 VAC (one leg of the 240) to provide power to operate the control panel. So... every time a start is attempted, the line becomes unbalanced, the 120 VAC to the control panel suddenly drops, the control panel resets, removing the load, the 240 VAC line becomes balanced again and appears normal.
Jan 07, 2010 | Washing Machines
It doesnt throw the flame to dry
The typical gas dryer set up: A thermostat is positioned on the blower housing to judge the drum temp. Next to it is a fuse.cd4488c.jpg If the temp exceeds 350F then that fuse melts and kills the heat but the dryer will still run. When that thermostat wants heat it sends 120 volts to the gas assembly. The gas assembly consists of 2 coils a sensor and an ignitor. The coils work on 120 vac but they are tenderfoots. If anything is running on the same circuit with them they don't cooperate. Enter the big bad ignitor and its cousin, the flame sensor. Both these partners in crime work together to coax them coils into opening. How? The sensor ALLOWS power to the ignitor. When the ignitor is glowing hot as 3 yards of C of C hell then the sensor's bi-metal shuts that glow thingy down. This gives them voltage starved coils a chance to get busy. The surge of power energizes them coils and they yank up the gas gates, the raw gas flows out onto that screaming hot glow thingy and BOOM! Houstion we have ignition!!
As the temp rises inside the drum the control thermostat decides enough is enough and kills power to that gas assembly. The drum continues to rock and roll till the temp cools off and then the control thermostat calls for more heat. So what can go wrong? The flame sensor can die and not put power tot hat ignitor. The ignitor can die too. or both can be ok and the coils work a tad and then get hot and quit.
Aug 21, 2009 | Dryers
I have a gas whirpool senseon dryer model number ggw9868kq0 that won't heat up all the time. The heating element lights up and then goes out 10 seconds later. The thermal fuse is good and I replaced the...
Hi, If the ignitor glows and then shuts off before you get a flame, then you will need to change the coils on the top of the gas valve. This is the most common problem with the gas dryer not heating consistant. Make sure your venting to the outside is cleaned out. A plugged went causes the coils to go back quicker.
I hope this helps and please let me knw if I can assist you further.
Thanks
Vic
May 11, 2009 | Whirlpool LGR5636L Gas Dryer
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
