Question about Lasko 1850 Stand (Pedestal) Fan
The power is on but the blades aren't moving on my pedestal fan
    Master:
  • 328 Answers
If it was old fan
probably it needs cleaning the Axe and lubricating it the dust is catches the lubricating grease until it cant run anymore and if ran it will heat up an burned
hope i was useful sir .
Posted on May 22, 2011
Blades moving but cant feel no air
if it is a newly installed overhead fan check the fan direction switch just above the motor
Jun 30, 2016 | Dryers
Blade won't turn. comfort zone 16in.3speedwhite oscillating pedestal fan
I believe your motor is shot. Time for a new fan, I'm sorry to say.
Dec 11, 2014 | Dryers
I have a 30" pedestal fan that is missing the blades. I want to get replacements.
i would google the model number and/or the brand name "pro standard" and see what comes up, find out who the manufacture is and then contact them, just replacing the blade with another that might fit can lead to death of the motor, the pitch of the blade is the critical factor too much and you will overload the motor, causing it to go out on overload or just burn it out. not enough pitch it will work but will be less efficient ie... not move as much air as the original
Jul 09, 2012 | Dryers
Dayton 24" pedestal fan -
there are 3 fan blades available on ebay: http://compare.ebay.com/like/220783606184?ltyp=AllFixedPriceItemTypes&var=sbar
Jul 20, 2011 | Dayton (2C373) Fan
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
Good luck from Detroit, MI.
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
Have an expensive Hunter indoor/outdoor pedestal Fan that stopped working. It just "hums" and does not turn. Please help.
With the fan UNPLUGGED, try to spin the fan blade with a pencil or something that will fit through the blade cage.
If the blade spins easily, there is an electronic problem (control or motor) that must be serviced.
If the fan blade is stuck or very hard to move, the shaft and bearing are probably dirty and need to be cleaned. You can temporarily fix this with a tiny amount (a drop) of WD-40 applied to the shaft where it enters the motor. Spin the blade manually to work the oil into the bearing. If the motor spins freely, the dirty bearing condition is verified. To properly clean the shaft and bearings, the motor must be disassembled.
Jun 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
Pedestal fan motor
you may be able to get a replacement motor in your area,but it will most likely cost as much as a completley new fan.these type motors in my area usually run around 100.00
May 26, 2009 | Hampton Bay 92650 Stand (Pedestal) Fan
Pedestal fan motor
Go to this link and find the dealer local to you; http://hamptonbayinfo.com/Product.aspx?pid=9eb435cd-4f97-4074-bdf3-630f1efd7a83&cid=791075 They should be able to either supply parts or tell you where to get them. Hope this helps, sorry for the delay but there are more problems than experts available at the minute :)
Mar 18, 2007 | Hampton Bay 92650 Stand (Pedestal) Fan
Lasko 1850 Stand (Pedestal) Fan Logo
376 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
