Question about Vacuums
Lost Power Cord during Move. Can we replace it?
    Master:
  • 328 Answers
Sure you can eve replace it by your self buy a long 3 meters thick electric wire buy a plug socket for it and open the screws of the vacuum cleaner face at the back of power plug socket you will find tow screws install the pair of wires on the pair of socket
test the cleaner
then assemble back
Posted on May 22, 2011
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
Short in power cord
Replace the power cord
Jun 04, 2012 | Simplicity Vacuums
I have a Miele Solaris that is having an intermittent power problem. The power will not turn on unless I push the cord winder button at the same time as the power button. I have disassembled the vacuum and...
These type of cord retractors have a set of contacts which sometimes get corroded or bent. Or maybe the reel has become wobbly.
As the cord reel moves, these contacts should have enough pressure stay in contact with the tracks on the reel at all times.
You sound like a handy person, so you would have to take the assembly right out of the machine and perhaps be able to correct the situation.
Some of these contacts are easily accessible, and others not so easily.
While you have the old assembly out anyway, you also might be able to buy a new one to replace it.
Without a close look it's hard to guess what to advise you.
Maybe a vac repair shop could throw in an tune up as well?
Check the motor brushes and so on?
Jun 17, 2011 | Vacuums
My Heritage II just lost power in the middle of vacuuming. The switch will turn on but no power.??? What is wrong?
It could be the switch that has become defective (the 'feel' of the switch may be different, but needs to be checked with a meter). Another possibility is that the cord has developed a loose connection at or near the power plug. Turn the switch on and wiggle/push the cord near the plug. An intermittent connection is indicated by the motor turning on and off. If so, cut the plug from the cord (they are usually a molded device that can't be serviced) and install a replacement plug from a hardware store or home center. If the switch is determined to be bad, order a new one from an appliance parts store or vacuum repair center. Good luck!
Feb 20, 2010 | Kirby Heritage II Vacuum
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
No power to vacuum
try using a couple of different outlets .move the cord around at both ends you might have a bad cord
Apr 29, 2009 | Vacuums
I have a hoover upright bagless - turbo power 6500 The cord has been run over and I just noticed white stuff on the cord where it is tattered. My husband said he saw it 6 months ago and never said...
It can be potentially dangerous. What you see is the cord insulation, if you move that a little you can see the power wires. They are coated and cannot hurt you if not damaged. If i were you i would wrap it in electrical tape or best thing would to get it replaced. You can replace it your self. Order the cable from Sears Parts store(link to your model)then your husband can install it. But not to sound rude if he didnt say anthing about that damaged power cord he may not be the right person for the job. He should have known it could be dangerous and thankfully your child wasn't hurt or you two either.
Here is the part number (Part# 46383334) and it will cost you about $20 plus shipping. The cord is item number 63. Let me know if you have further questions./
Jan 08, 2009 | Hoover U6616-900 WindTunnel Bagless...
Steamer #410 has cord problem
u can send it back or u can fix it urself its a simple fix all u have to do is check the power cord going in u can cut about an inch n reattach it and it should work good luck
Nov 16, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
