Question about Daewoo DTQ-27S5FC 27" TV
Does TV have a fuse or reset button? Where are they located?
  • klaucks May 29, 2011
    No more problem - put TV out for the trash.
    President:
  • 2,992 Answers
Yes, all TVs have a fuse. You'll usually find it in a spring-clip holder on the circuit board inside the cabinet. Look for it in the area where the power cord connects to the board. Most TV sets use a small cartridge fuse, but some sets use a different type.
If you're asking this because your TV has gone dead, just be aware that if the fuse is bad it's normally because something else in the set failed and caused the fuse to blow. Fuses very seldom just go bad on their own. If you change the fuse, don't be surprised if it goes bad again.
And while this should go without saying, I'll say it anyway: be sure to unplug the TV from the AC outlet before taking the back off. You can get a nasty shock if you forget this step.
Posted on Jun 03, 2011
Is there a reset button on a vizio lcd 32 in flat screen tv and where would the fuse be located what happen was my husband accidentally touched the usb where it says sevice with a wire and the tv just...
Hi Kaycee.
I suggest you try to reset the power to the TV:
Start off by turning the TV off and unplugging it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
Hopefully this will get it working for you.
If this does not solve the problem, you can go to the online video, "How to Power Cycle a VIZIO TV" - see attached video.
Reference is
https://answers.vizio.com/hc/en-us/articles/200132879-How-to-Power-Cycle-a-VIZIO-TV
Hope this all helps you
Mar 04, 2015 | Vizio Televison & Video
Where is the fuse and reset button
The fuse can be located at its main power supply regulator board. There is no external reset button.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 07, 2014 | Televison & Video
It acts like no power to it ,I have checked the cord and fuse ,does it have a reset button ,if so where is it located
Try to check the on and off push button switch, check if the switch functions properly. Stuck switch terminals sometimes causes that problem.
Nov 17, 2010 | RCA 27F530T 27" TV
Where is the motherboard reset button located on sony tv kp-46wt510
No button on the main board. But, you can reset the TV by holding down the 'Reset' button on the TV remote and then pressing the 'Power' button on the TV control panel. This will cause the TV to Factory Reset. I hope this was helpful, best wishes.
Apr 12, 2010 | Televison & Video
TV Won't Turn On
there is no reset button - the main fuse has probably blown and needs replacing (6.3A 250 V)
Dec 26, 2008 | Panasonic CT-32HX42 32" TV
Fuel pump reset button
Never heard of a reset button.
Look under the hood for a fuse and relay center. There might be a Maxi fuse for the fuel pump.
Nov 05, 2008 | 1991 Toyota Camry
RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Feb 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Location of fuse
Take the whole thing out and bench test it. You will know where the problem is and save alot of guessing times. Goodluck.
Sep 29, 2007 | Kenwood Excelon KVT-915DVD Car DVD Player
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Toshiba TV problem
No reset button, try unplugging the set for 1 min, the plug back in, otherwise Tv Tech time.
Jul 08, 2007 | Toshiba 36AX61 36" TV
Daewoo DTQ-27S5FC 27" TV Logo
69 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
