Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX25ZP - ice maker works, but door dispenser for ice does not work. Water dispenser works fine. At first crushed ice stopped working (no noise or anything), then after a few weeks the ice dispenser stopped working even though you can still hear the motor running.
catriver
  • 878 Answers
SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Posted on Jul 24, 2006
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
larryyb
  • 291 Answers
SOURCE: GE gss25ifrf ww Ice maker
you will need to replace the dispensor board part number WR55X10444
Posted on Dec 04, 2008
jeffbvegas1
  • 520 Answers
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Posted on Jun 28, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water at door stopped working. water still comes to ice maker. no damage to electronics panel. Ice dispenser, whole and crushed works fine. is there a relay in the water circuit that fails? Or, is a...
I have the exact same problem. Ice maker works but nothing at the water dispenser. The light come on when I press the lever and I hear a click. But nothing like water "trying" to be pumped. I am nervous it is more than just a frozen water line. Anyone else have this problem or a solution?
Dec 09, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
130 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
