Question about Briggs Stratton Portable Generator 305cc Engine 8250 Surge Watts 5500 Running Watts Model 030439
Engine does not idle back with no load. - Briggs Stratton Portable Generator 305cc Engine 8250 Surge Watts 5500 Running Watts Model 030439
Where is the air control sensor in a 2001 oldsmobile silhouette?
It's called IAC - idle air control valve > Did the RPM'S stay at 2000 or drop back down ? The PCM engine computer controls IAC valve according to engine load . Put it in gear , turn on electrical loads , headlamps , A/C etc... an the RPM raise's up so engine will not stall . More then likely the throttle plate needs to be cleaned , they get gummed up an stick at higher idle . Quick Tip Throttle Cleaning EricTheCarGuy If the IAC valve were gummed up the idle would be low or erratic . On some engines a vacuum leak will cause high idle . Videos on youtube checking for vacuum leaks .
Jul 24, 2016 | 2001 Oldsmobile Silhouette
My welder will run and weld fine at high idle speed but shuts of when the low idle kicks in. Checked fuel system to see if it was a fuel issue, no problems there. Any ideas?
If you're trying to weld at low idle it may be that the load on the engine stalls it before it can automatically go back to high idle.
You may need to "trick it" back to high idle before you begin welding.
Aug 19, 2015 | Cars & Trucks
Bike will sit and idle for over hour but if u ride it after ten 15 min it will lock up back tire and die then hard to kick after cooling down will fire back up
1. idle speed is a "no-load" situation.
2. Riding is a "load" situation. - This is when the problem occurs!
This could be something simple or very complicated to diagnose ... its time for a top notch professional... not just some parts replacer!!!!!
I gave seen a quad that would idle fine, even when warmed up, but try and race it and it would overheat and lock up. The problem was a BENT connecting rod, from forcing the engine to turn over when the engine was FULL of gasoline! (Forcing past a hydraulic lock situation!)
Jul 25, 2014 | Motorcycles
Car wont idle after start.
Hi david its a focus with bad idle the pcv pipe is broken its connected in the back of the trottlebody i change dozen of those ill try to find you a video about it
Apr 10, 2014 | 2001 Ford Focus
Car Idles up and down when warmed up
Could be your IAC (Idle Air Control), leaking throttle body base gasket, or a throttle position sensor
Feb 16, 2018 | 1998 Chevrolet Camaro
My Woolf 900 generator starts fine initially. When put on load (600w) it is reluctant to get up to speed (45secs) but eventually gets there. When load is taken off it doesn't go back to idle and event
Does it have and automatic idle? If so cut it off and see if engine can run at 3600rpm no load. If still stalls, your jets(brass tube) have something blocking holes and carb needs either a real good clean in a dip, rebuilding, or replacing.
Jul 09, 2013 | Electrical Supplies
I have a 175 pull behind IR compressor. When trying to set the high Idle I open the valve so that it is reading 100psi, the motor trys to throtle up but it seems under to much of a load. also when it drops...
100 psi is around the pressure that the engine goes back to idle
it should start to go to fast rpm when the pressure drops to around 75 psi
if it is trying to increase rpm at 100 psi , the engine is under load and that is your problem
Dec 19, 2017 | Ingersoll Rand P185WJD Platinum Series Air...
My 02 Camry v6' battery was removed for 30 min and put back on - good battery. Engine starts no problem but stalls at idle. No error code. Is a computer-code reload or IAC cleaning ? Seems the car computer...
idle learn procedure:
turn off all electrical items (AC fan, audio, lights, defogger, etc.)
Start the engine and hold it at 3,000 rpm with no load (in park or Neutral) until the radiator fan comes on or the engine coolant gauge shows normal running temp.
Now let the engine idle for a minimum of 5 mins with no electrical loads. If the radiator fan cycles on during this time, you must add the fan running time to the 5 mins.
Feb 10, 2011 | 2000 Toyota Camry Solara
Adjust the motor idle on a 1974 evinrude 50
Seat the idle mixture screw. Turn counter clockwise 1 1/2 turns. With engine running in gear under a load at idle slowly turn the screw clockwise until the engine bogs down and then turn back out 1/2 a turn. That is your correct mixture.
Sep 29, 2009 | Boating
Briggs Stratton Portable Generator  305cc Engine 8250 Surge Watts 5500 Running Watts Model 030439 Logo
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
rlev_7
Level 1 Expert
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
