Question about Kenwood KW85 Air Conditioner
I GET A E4 ERROR CODE ON MY KENWOOD KW80. I TRIED THE PROPOSED PROCEDURE WITH THE REMOTE CONTROL BUT I DON'T SEE ANY "C" BUTTON ON IT. REMOTE MODEL IS ZCF/LW-09
  • PIERRE ARPIN May 25, 2011
    I cleaned the sensor with a cotton swab dipped in alchool but the problem still stands.
    I lloked at the PCB to check any dirty contacts but I always get the E4 error code.
    Where I can order a new board to make the replacement myself ?
  • PIERRE ARPIN May 26, 2011
    No, I still get the E4 even if I put the wire as mentioned in your message.
    What can I do now ?
  • 910 Answers
E4 is a 'Fault' with the Air In Sensor. It may not be fault and could just need a good clean.
If you start by removing the grilles and clear any blockages, behind the Air Intake Grille you should be able to see the Air In Sensor, make sure this is clear also.
If this fails to correct your problem then you will need to have the Air In Sensor or Main Control PCB replaced.
Posted on May 22, 2011
  • Andy Turner May 25, 2011
    If you can see where the Air Sensor connects to the PCB, try connecting a small piece of wire across these 2 terminals to simulate the Air Sensor being OK. If E4 Error goes away then the fault is with the Sensor.
    Please advise of result and I'll see what I can find for replacement parts.
  • Andy Turner May 26, 2011
    These parts are not available to the public so you need to contact your local Kenwood/De'longhi service agent.
Just purchased a1991 honda accord with a kdc 6015 car/stereo cd plyer and i do not know the code it is akenwood
Hi.Kenwood radios can be reset using a special mastercode which is 5 2 2 7 (this is known as KCAR)
You will need the remote control of the radio to enter this, if you don't have one, then you will need to go to a local Kenwood agent and purchase one - unfortunately there is no other way around this.
Procedure to follow;
Jan 08, 2012 | Car Audio & Video
I need your help to know the code its No 11201951
Here is some good info from another site (as linked below):http://www.tech-faq.com/how-to-reset-a-kenwood-security-code.html
If these methods don't work you would have to send the stereo back to Kenwood to be reset.
Common Kenwood Security Codes Many Kenwood radios are configured with the same security codes:
  • KCAR - This seems to be a "backdoor" to some Kenwood models.
  • 3051 - This is the security code which is printed in the manual of many Kenwood models.
  • 1234 - This is a security code commonly chosen by Kenwood owners.
kenwood-security-code.jpg Entering your Kenwood Security Code If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
  • During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
  • Enter the security code using your Kenwood remote.
Type 2
  • Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
  • Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter - then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
  • 5
  • 5
  • Track Up
  • 2
  • 2
  • 2
  • Track Up
  • 2
  • Track Up
  • 7
  • 7
  • Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in Some Kenwoods There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jul 01, 2011 | Kenwood DPX-6020 CD / Cassette Player
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
May 31, 2011 | Kenwood Dishwashers
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
The RC R0509 remote control does not respond to the receiver. I bought a universal remote and tried all the codes but still no responce.
people say that you have to tap on the receiver near the remote sensor. I don't know exactly where that is though since these are RF (radio frequency) not IR remotes, so there isn't a sensor panel in the front. I'd just tap along the front edge with the handle of a screwdriver or something. People say it works a treat.
Dec 05, 2010 | Kenwood VR-405 Receiver
My Kenwood Dishwasher shows an E4 error code
Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
Aug 25, 2010 | Microwave Ovens
I need the remote control codes
Check the following link for all codes for URC7030
http://electro-medical.blogspot.in/2013/12/universal-remote-code-for-urc-7030-sony.html
Mar 12, 2009 | Zenith ZEN350 Remote Control
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Kenwood KW85 Portable Air Conditioner
Using remote control "on" the unit, then push the C button of remote control, if the C display at the unit "off" the unit using also the remote control. Unplug the power supply then plug again and start the unit using the remote control.
It the instruction above don't solve the problem, the return air sensor is out of range or the main board of the unit itself is defective. You need a qualified tech with this problem.
Oct 15, 2007 | Kenwood KW85 Air Conditioner
Kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KW85 Air Conditioner Logo
305 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
