This probably means the thermostat has tripped. It's a common fault
with these tumble dryers - it may be possible to fix it by resetting the
thermostat:
Unplug the machine!
Remove the heater assembly (rear of the machine - two screws to remove
the spindle cover then another half dozen screws and the heater assembly
comes away).
Take out the heater - two screws hold it in.
At the top are two thermostats - a white one and a black one. The black
one has a small hole in it and can be reset by pushing a pin into the
hole until a 'click' noise is heard.
Reassemble, plug back in and test.
Note that even if this fixes the problem the unit will probably show F10
a few weeks later; I think it's just the way these machines are - a
design fault.
If the above doesn't solve the problem then it may be worth buying
replacement thermostats - a kit will include both the black and the
white on... Hope this helps Tim
