Question about Home
How much water does a batroom sink hold. I think it holds about 3 qts. But my father tells it depends on the company that makes it.
  • 843 Answers
Yes, there is quite a range of sizes of bathroom sinks. 3 qts would be on the small side. There is no standard.
Posted on May 22, 2011
How to disconnect sprayer hose on kitchen faucet?
Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
Things You Will Need
  • Pliers
  • Towel
  • Pipe-joint tape
  • 3/8-inch threaded brass flair cap
  • Basin wrench
  • Sink hole cover
Dec 01, 2017 | Plumbing
What is a galley holding tank?
The galley holding tank holds the grey water from the galley.
May 24, 2017 | RVs
Is there a drain bolt for the ATF on a 2004 toyoya solara
most toyotas do have a drain bolt on transmission pan for draining the fluid, i would make sure you are draining at the correct time, this depends on what type of oil it uses. i think it is the TIV. call dealer and make sure ,the drain and refill holds 3.7 qts.
I can tell you this, i do not like the drain and refill , you are only draining 3.7 qts, then you add new oil to mix with the rest of the dirty oil in transmission,
The best way is to flush system using a BG flush machine or compatible machine, this way 100% of the oil is removed and replaced with new.
Mar 31, 2013 | 2004 Toyota Solara
Remove bathroom sink flange
Turn off the water valves at the back of the sink and place a bucket underneath the drain to catch any water that may run out.
2 Loosen the nuts that hold together the drain tailpiece and the P-trap with a wrench. Disconnect the the two pieces.
3 Unscrew the drain tailpiece from the drain flange. Depending on how the drain flange is held in place, you may need to hold it down firmly as you twist the tailpiece below. Remove the tailpiece and set it aside.
4 Remove the old drain flange. It may come straight out after the tailpiece is removed, or it may be held in place with putty or silicone. If it is held in place tightly, grasp the edge with a pair of pliers and pull until it comes free.
5 Wipe down the sink area that was underneath the old flange. If the metal was discoloring or rusting, clean the porcelain well and dry it to keep the new flange clean.
6 Apply a thin bead of silicone caulk to the underside of the new flange. Push the new flange into the drain hole in the sink.
7 Push the drain tailpiece back up into the sink's drain from below and screw it into the flange tightly. Use a wrench to tighten it up securely.
8 Reconnect the P-trap to the tailpiece and tighten the nuts that hold it in place. Turn on the water supply to the sink and run water through the pipes to ensure everything is securely fastened.
  • Bucket
  • Pliers
  • Adjustable wrench
  • Silicone caulk
Duplex Steel flanges Duplex Stainless Steel Flanges Manufacturers Suppliers Instinox
Feb 12, 2012 | Kohler Plumbing
MY granite sink arrived and a large corner of the back where the holes are for the faucet is broken off. Since I have had the sink swince Feb. 18th unopened unmtil tonoght I don't think the company or UPS...
I would think it is worht a try. use some epoxy for granite and also glue something to the underside of it to beef it up, plus it will help hold the break togather with a clamp or two.
Mar 08, 2011 | Granite Home
Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
RJ
Nov 07, 2010 | Culligan Under Sink Water Filter
Looks like our GE Profile tbx25pa has rust on drain through.is this repairable?
let me guess, and water is dripping into the refrigerator? Sometimes it is necessary to replace that drain trough from underneath / behind the evaporator coil. But, there is a more likely problem. If you pull your refrigerator out from the wall, you will see a black 1/2" tube coming up from behind the machine compartment cover. at the top of this tube is a black, drain diverter, which has an outline in the mold similar to the elbow underneath your kitchen/batroom sink. 90% of the time this diverter gets clogged with gunk, preventing the water from going down that 1/2' tube to the pan under fridge, instead, it drips down the back wall of your refrigerator, pools under the crisper drawers.
To see if this is your likely problem, while holding the diverter firmly against the back wall of the refrigerator, you dont want to damage the plastic "hooks" that hold it firmly against the back wall...holding that diverter, grab the middle of the 1/2" tube, or to prevent some splashing of yucky water, grab it closer to the diverter and bend the tube towards its middle, while pulling the tube out of the bottom of the diverter, you wont have much, if any water coming out, maybe an ounce or two. leave the tube as it is. Now slowly rotate the diverter clockwise, less than a quarter turn, you will feel it loosen when the "hooks" have cleared the tabs in the opening. take this diverter to the kitchen sink, and pour some water into the large hole, does the water come out the bottom, where it would normally feed into the 1/2" tube? No? thought so. keep rinsing and shaking the diverter, you will see all kinds of gunk come out, shake it REALLY good, tap it against the sink, loosen up everything. go back to the fridge, look up into that hole, pull out any gunk you see in there, put the diverter in the same position it was when it released, turn it back counter clockwise, while holding it in place, put the 1/2" tube into it, and voila.
however, if you didnt notice any gunk in diverter, and water went through before cleaning it out, then it is possible, that the rust in the drian trough has a SMALL hole, which is bypassing the plastic tube that feeds water into the diverter, thereby dripping into the fridge, THEN you will have to have your trough replaced, BUT, because of the process required to remove and replace that trough, you could cause serious damage, and lots of money to fix, and any company shouldnt charge you more than around $150 to do that.Thats what I would charge you.
Feb 23, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
I have an 1995 subaru legacy with auto trans. Can anyone tell me how many quarts of fluid it takes
i think its 5 qts dexron II but if you look in the owners manuel it will tell you exactly
Aug 25, 2009 | 1995 Subaru Legacy
I have a 1994 heritage after changing oil and filling it to the full mark on the dipstick, I rode it 80 miles the next day I checked it again and the oil tank is over filled ???.What happened.
You over filled it, depending on the type of dipstick you have, the oil is checked either on the side stand or with the bike upright. If you have the type of dipstick that is floppy (the stick part flops around) you have to check the oil while the bike is on the side stand.
Regardless Softtails hold 3 quarts of oil, if you add exactly 3 quarts after draining the oil bucket and changing the filter the oil level will be correct (unless the oil has sumped).
The other thing that happens sometimes when the bike sits for any period of time without running the oil can sump from the bucket into the engine crankcase. If this happens it will look like you are low on oil, so if you go adding oil and then run the bike it will unsump and overflow the bucket making a hell of a mess.
Hope this helps you.
Jun 08, 2009 | 2000 Harley Davidson FLSTC Heritage...
Cold tap doesnt work
Is it a single handle or double handle faucet?
If it is a single:    1.  Remove handle via setscrew the side of the handle          (possibly under a decorative cap with the company name)    2.  Unscrew the packing nut holding the valve cartridge in    3.  Remove cartridge and access washers
For double handle    1.  Remove decorative cap on top of handle with a think screw driver.    2.  Remove handle and packing nut holding the valve stem in place    3.  Remove valve stem and body to access washers and o-rings.
Remember to turn water off at the source prior to doing any work. Replacement is just reverse of removal and don't forget to use a washer grease on all washers/o-rings when reassembling.
Apr 14, 2009 | Swan Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
