Question about John Deere Garden
Hello Sir, I have a john deere 25 horse 48 inch cut,the first thing that happen was the orange button you push to back up with blades engaged quit working and then the blades wouldnt come back on after disengaging them can you help me please?
    President:
  • 3,074 Answers
Sounds like the switch is bad, you will need to check it, as it may be just a loose connection, you can jump it out to test it out, or just straight wire it. Good luck Tim
Posted on May 22, 2011
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Have lt155 john Deere mower. When cutting blades are engaged, pushing reverse pedal all the way down cuts out motor. Yellow lockout button is also pushed in.
A lot of mowers have a safety feature built into them that don't don't allow reverse mowing, there is a sensor switch that cuts the motors when depressed. you can however override this safety feature by removing one of the wires off the reverse pedal depress switch, but do so only if you are a competent confident user of the machine. And remember to reconnect the wire if there will be other users.
Apr 28, 2015 | John Deere Garden
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Belt comes off my John Deere L A 110 42 inch cut when blades are disengaged!
3 things:
1. disengage the blades and allow them to come to a complete stop before reducing the engine RPM
OR
2. adjust the belt tension by loosening the bolt where the cable to engage the blades is attached to the maximum.
OR
3. replace the belt.
Jun 30, 2010 | Garden
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
John Deer X475 lawn mower
Check fuses.Does the dash light for PTO come on?Right side screen by pedals sometimes comes in contact with wires and cuts them.This happens mainly on the older units.
Sep 19, 2009 | Garden
Garden Logo
89 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
