Question about Cameras
Cant take picture because card protected how to solve
There shoud be a very small piece on the card, which you can lock or unlock the card. http://www.faqs.org/photo-dict/photofiles/list/1354/48741_gb_sd_card_1174%5B1%5D.jpg it this url , there is a small yellow piece on the left. you can change protection preferences by moving it up or down.
Posted on May 22, 2011
Camera. Card's write protect switch is set to lock
i try to write protect my pictures on my camera canon eos rebel t3 after that i cant snap i cant do anything when i press the shutter button then it write cards write protect switch is set to lock please help me
Feb 06, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
I cant take photos anymore and the LCD screen says CARD'S WRITE PROTECT SWITCH IS SET TO LOCK.How can i solve this problem?
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
Dec 28, 2011 | Cameras
I put my memory card in my camera and it says protected card how do i use it on my new camera?
Your memory card is protected and this is why you cant take pictures.
To solve the problem do the following:
  1. Remove the memory card.
  2. On the side of the card you will see a switch. This locks or unlocks the card.
  3. Change the switch to unlocked by either shifting it up or down.
  4. Put the memory card back into your camera.
Your problem should now be solved!!
Enjoy taking pictures!!
Regards
Jan 07, 2010 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Fujifilem Z20fd I cant turn the card protection off which appears
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Is your flash working? Do you have the flash turned on?
Jul 11, 2009 | Fuji Finepix Z20fd Digital Camera
Protected card pops up and i can't take or delete any pictures, but i can look through the pictures.
remove the card. there is usually a switch on the side. turn it to the other position.
Apr 19, 2009 | Kodak EasyShare V1073 Digital Camera
Protected card on screen
If you remove your memory card there may be a little slider on it that is in a "lock" or "protect" position. This is true for SD cards, and there may be similar sliders on other types. Hope this helps.
Apr 19, 2009 | Cameras
Removal of write protection
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the memory and then you will be able to use it again. To format the memory: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the memory can be used again.
Mar 22, 2009 | Olympus Camedia C-480 Zoom Digital Camera
Mar 22, 2009 | Olympus FE-320 Digital Camera
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
Look at the memory card and see if there is a write protect switch on in.  if there is then change the setting
Jan 14, 2009 | Motorola Mobility MOTOROKR E6
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
