Does wash ok,but will not rinse or spin - Washing Machines
  • William Tinning
    William Tinning May 22, 2011
    magic ,filter was blocked with a sock -water everywhere but m/c now working .
    thank you
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
First, test the door lock-switch mechanism, if that tests fine and the drain pump filter assembly is clean then get back to me with its make and model# if you have any other questions.
Kevin
Posted on May 22, 2011
  • Kevin White
    Kevin White May 22, 2011
    LOL...GREAT....give a 4 thumbs rating if you found this helpful
When i put my washing machine on wash the mains power goes off, it works on rinse and spin.
It would appear that something is wrong only on wash cycle. The motor wouldn't be faulty as you say it still spins and the water valve must be Ok otherwise it wouldn't fill for a rinse. The heater does not operate on rinses so I would suggest you have a short on the heater element or the wiring for it.
Mar 08, 2015 | Washing Machines
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
After washing and rinsing it doesn't spin the water out.
Check the drain lines for clogs. If that checks out ok, then you probably have a bad drain pump.
May 11, 2012 | Miele Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Znaussi FJS 1025W Won't spin/rinse
Hiya pat, not sure about the right answer,Make sure its pumping out ok then spin should bee ok ..motor will run slow if motor brushes are worn , happens after about 5 yrs...hope this is of help to you
Apr 11, 2010 | Washing Machines
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
