Question about LG Televison & Video
ILO pdp 4210ea1 is working exept that the image is dark and fuzyy sound work .The voltages look in range ,i dont check for ripple .look like something along video signal or britness control.where to start eny sugestion appreciate .
    President:
  • LG Master
  • 775 Answers
What you most likely need is to service or replace the ZSUS board 6870QZE017D. There's a good chance the fuse on it will be open - check it if you can.
Replacing the fuse likely won't help - it'll either blow again or will make the TV shut down.
Feel free to send the board for repair or buy a new one.
www.coppelltvrepair.com
Posted on May 22, 2011
Sound isn't working on my pioneer 5071 pdp
Does the set have sound with a DVD etc. directly connected to one of the audio/video inputs this set has?
Apr 30, 2012 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Tip
A) basically it has to be acted upon by a supply voltage of at least 95V to...
a) basically it has to be acted upon by a supply voltage of at least 95V
to work.
sample picture
b) of course, assuming the horizontal deflection oscillator works, same
with the horizontal drive and horizontal output transistor
it would generate output voltages on the secondary terminals
and 200V line will be active sending voltages to the
Video Drive circuits. Of course high voltage will be generated
ranging to at least 30 KV and there will be voltages on the G2 of the tube.
c) the easiest test point to look when it is oscillating, is the CRT heater
voltage, the heater lit when flyback is good ( mostly at night times when it
is dark ) and you can hear sounds, too.
here is a sample image
marked with letter H and H1
Green Arrow for the G2 voltage
d) having a B+ voltage reading of 75 V or lesser ( primary pins )
indicates a bad or partially shorted flyback, assuming your
horizontal output transistor and power supply are good & OK.
sample of H out
These only applies to CRT type TV's.
on Dec 24, 2009 | Music
Picture has suddenly become dark and greenish Tried to fix with brightness, color controls...can change to dark and reddish...but thats it. is either PDP 4214HD or PDP 42A3HD
Is tv plasma or lcd (how old). it may be the screen or pannel has lost its efficiency. A bit like old tv's tube going. You did the correct thing by adjusting controls but this sounds like a workshop job
pete
Nov 08, 2010 | Pioneer Televison & Video
Tv very dark what can i do brightness tured up full still very dark
First check this points:
1. How old is your TV.
2. How many times you have change your lamp.
3. Any sort of weird sounds on the back of the TV.
If you are having problems whit the brightness of your TV or you are seeing a dimmer picture, you might have to change your lamp or your ballast, if it comes to a point where you do not see any image at all but you still hear a sound, then its definitely the lamp, if you dont see image or hear any sound, you might have problems with your ballast, also when your ballast begins to run out the picture can get dimmer due to it sending less amount of voltage to the lamp, i suggest to check with a tech to confirm it, or get a second opinion. Hope i could be of assistance.
Mar 16, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
Headlight wont work exept on passing
Did you try measuring voltage to Headlight switch? If that works fine check it at headlight connection.I suspect corrosion.
Feb 21, 2010 | 2006 Yamaha Ybr 125
Weird water-like image distortion
this is electronic advice,dont do with yourself if you dont have experince about electronics,it will be very dangerous...if you have experience then you do this...
you open the lcd and you remove the power supply chips, it contains more capacitors like 1200mF 16v..i think so..but check the voltage if it is correct in the volt meter,caused the sounds like power distortion..if the voltage is less the screen will be "trembling and shaking, its like very frequent water ripples. This problem though dissapears as you move more and more to the right, but its clearly visible to at least no the 1/3 of the screens horizontal length." check
Mar 03, 2009 | ViewSonic VG2230WM LCD Monitor
No Picture
Hi washingtonrm,
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 22, 2009 | iLO 2600 Television
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Jan 10, 2008 | iLO 3200 32 in. LCD Television
Need help
Hello koty,
That sounds like you may have a problem with a bad solder joint on one of your switching transformer connections. If you have a soldering iron and some solder, you should resolder the transformer connections. Also check the whole board for bad solder joints. If this does not work there might be a chance that one of your capacitors has gone bad due to aging. You will need an oscilloscope and a schematic to measure the voltages on the capacitors to make sure that they are within the recommended ripple voltage range (open capacitors loose their ability to filter so the ripple voltage increases and this causes instability in the DC voltage level). However the fact that when you apply mechanical pressure the problem abates, this is pointing towards a bad solder connection.
I hope this helps,
Thank You,
Shuttle83
Apr 28, 2007 | Rockford Fosgate Power 1500.1BD Car Audio...
Televison & Video Logo
46 people viewed this question
