Question about PfaFF Creative 7570
The bobbin winder is making a horrible screeching noise.
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
My 1130 bobbin threader turns, but will not wind thread.
Check that the bobbin winder is snapped all the way over.
Sorry, unable to provide more help, but a standalone bobbin winder may be helpful. You can find one brand (called "Sidewinder") at sewing stores like JoAnn's or online for ~ $30. Just verify that your bobbins will work (some Singer bobbins do not), but I assume your machine is a Bernina. Even if your bobbin winder is repaired, this standalone bobbin winder will save wear and tear on your machine--also, makes it so-o-o-o much easier to wind a bobbin without first removing the thread from your machine.
Oct 10, 2016 | Sewing Machines
Why won't the bobbin winder work
Difficult to diagnose without knowing the make/model and the symptoms. Best advice is to consult the owner's manual.
Make sure the handwheel center cap is loosened before winding the bobbin. Also, snap the lever toward the bobbin to activate the bobbin winder. Confirm that the correct sequence is followed in threading from the spool to the bobbin winder.
If you are unable to get the bobbin winder to work, for ~$25 you can pick up a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Nov 10, 2015 | Sewing Machines
When I wind a bobbin, it makes a screeching noise and the needle goes up and down. What step am I missing ?
On the right side is a big wheel and in the middle a smaller one. You need to unlock the smaller wheel so that the needle mechanism does not run when re-winding a bobbin. You need to use both hands to do it. Hold the bigger wheel and then loosen the inner wheel anti clock wise. Once you have finished loading your bobbin you need to tighten the inner wheel again for the machine to be fully functional again.
Jan 12, 2014 | Singer 7436 - INGENUITY
Pfaff QE4 (a couple of months old)--the bobbin winder will not function, makes a huge clacking sound.
Make sure the bobbin winder is pushed as far to the right as possible. If it is and still makes the noise the winder may not be engaging the clutch mechanism completely. The winder would have to be adjusted. Your dealer should be able to do that with no trouble.
Sep 07, 2013 | PfaFF Sewing Machines
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
clean under the needle plate
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
Aug 03, 2011 | Sewing Machines
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
Bobbin will not rewind
SE270D. Lift the bobbin and reposition, making sure it is down against the pin.
If this is not the problem, a Sidewinder Bobbin Winder (auxiliary bobbin winder sold with most sewing notions) is a lot cheaper than taking the machine in for service.
Mar 14, 2010 | Brother Sewing Machines
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
37 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
