My lg air conditioner (wall mounted) ls120cp wont turn on. ive reset the breaker but no luck. ideas?
    Guru:
  • 868 Answers
Hi callme_su,
You mentioned your airconditioner would not turn on at all.
Have you check the power connections or tried a different power outlet?
mvincentc
Posted on May 22, 2011
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Air conditioner repair
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioner Fort Lauderdale
May 25, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Lg air conditioner t-stat temp sensing bulb
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.Air Conditioning Coral Springs
WONT START
1) test the outlet wall, try to put some lamp for to see if there are voltage
2) reset the c. breaker or blown fuse replace
3) test the power cord
4) try again. if the problem persist you must test the following a) wiring break or open b) thermostat c) compressor d) overload relais e) selector switch for open f) control board
God bless you . see the diagram attached.
Jun 22, 2012 | LG LW1010ER 10,000 BTU Window Air...
A picture fell off the wall & hit the plugin, the unit went off. I tried the reset button but it still doesn't come back on. any ideas?
Check your circuit breaker. It may have tripped. It will be in the main circuit box, probably a 15 or 20 amp breaker.
Jun 26, 2011 | LG Electronic Window Air Conditioner
WILL NOT TURN ON
ckeck for a reset on the cord where it plugs into the wall push reset if so..check the breaker box the breaker could be off or triped ..good luck/joe/
Aug 25, 2010 | LG Heating & Cooling
Error code 61 on remote m#lc340cp
from your description it sounds like this only happened once .. if it happens over and over then there is a different solution ... if the system is shut off then back on right away it will sometimes trip the breaker . this happens often when you have a momentary power failure ... any time the unit is shut off you should wait for a minute before turning it back on .. that allows the internal pressure to drop so the compresser is not trying to start with a full load ..
Aug 20, 2009 | LG Art Cool LA121CNP wall/window Air...
IR Codes for LG ductless air conditioner
I, have a LS120cp lg ductless.The only way I,can get the unit to run is by pressing the test button on outdoor board.
Jun 04, 2008 | LG Heating & Cooling
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
