Question about Kenmore Washing Machines
My Kenmore 110.15952400 washer is staining my clothes with what looks like an oily residue, only on some clothing and not every load. It has done this for quite some time. Also, when filling, the water alternates from hot to cold, but the end result is never very warm. Is there an adjustment for this?
  • 583 Answers
SOURCE: kenmore 80 series washer leaves soap residue on clothes no matter
check the link: below
http://www.repairclinic.com/0088_11_1.asp
Posted on Mar 12, 2009
prasanth83
  • 68 Answers
SOURCE: Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
Posted on May 13, 2009
  • 58 Answers
SOURCE: kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Posted on Jul 01, 2009
canbruce75
  • 1776 Answers
SOURCE: starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Posted on Sep 07, 2009
  • 142 Answers
SOURCE: Looks Like oil on clothes
sound like gear box oil expensive.
Posted on Sep 14, 2009
Kenmore 70 series, leaves browb lines on clothes. is there cleaning procedure for the washer?
It could be coming from your fabric softner. I know when I use liquid fabric softner I get oily looking stains on clothes. I no longer use liquid softner. I also use Dawn dish soap in my washer. I use Dawn instead of any other stain removers. Dawn dish soap works on everything.
Dec 02, 2010 | Kenmore Washing Machines
Washer depositing oily stains on clothing HELP
Best way is the old fashioned way. Purchase some soda chrystals and pop them in ur drw. The same amount as you would normally use in detergent powder. Then put the washer on the hottest setting and wash the machine out. Do not put any clothes in the washer at the same time though. This will clean the washer it may take a couple of attempts to clean but doing this once a month will keep on top of it.
Hope this helps
Mar 28, 2010 | Whirlpool Washing Machines
Starting to leave brown oily like stain on clothes
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes come out with stains on them
I had a similar problem with my Kenmore front loader. Turned out that the rubber lining around the door was trapping dirty, soapy water causing a nasty residue to collect. That residue got onto the clothes. I cleaned the rubber liner and now keep the washer door open between uses. I still occasionally wipe down the rubber liner with a wet rag. Problem seems to have been solved.
Jun 13, 2009 | Samsung WF328AA Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
Kenmore Elite top load set
fabric softener will leave oily looking stains on certain fabric. oil stains will not wash out.i do not recommend using softener in washers it gums up everything!
Nov 03, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
102 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
