Question about Matsonic 8328E (MS8328E) Motherboard
My pc has power but the motherboard does not beep and nothing boots up
  • 44 Answers
Try pulling your memory sticks and turn on unit is there any beeps ?
if not the pull all pci cards, ie modems and video, optical drives, anything but main hard drive and turn on see if you get beeps then ONE AT A TIME replace cards till you find which one is bad \
That is if it is a hardware problem
Posted on May 22, 2011
Power light comes on but nothing happens
What type of laptop? What operating system?
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 22, 2012 | Computers & Internet
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
My Hp a1630n does not start up. It does not boot,no beep, screen displays 'no signal'
If it is getting no power at all to the tower, your power supply is probably dead. If you are getting lights but no beeping then it may be a matter of resetting your motherboard. This would entail opening up the computer removing the power cord and removing (carefully) the small watch battery on the motherboard. After waiting about 30 minutes, put battery back in and try to power up. If it still dosen't boot up then it's time to start removing parts and keep trying to boot up until you have narrowed down what the problem is. If all is removed and still nothing. Your motherboard is probably bad. Good Luck.
Oct 25, 2009 | HP Pavilion a1630n PC Desktop
Asus rampage 2 extreme no beeps on first boot, does not enter post, i.e nothing shows up on screen, with the 8 pin power connector in the motherboard the pc will boot then shutdown for 2 seconds and reboot...
1 - Test the memory in another pc; if it's at fault change it completely.
2 - That 8 pin connector is there to provide extra power to the processor sources - either one or more of them are fried = replace motherboard or the processor itself is gone =  test it in another pc and replace it if necessary.
Oct 25, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
When I go to boot the pc, it just beeps very loudly. Never boots.
thats normally means your video card has a fault, especially if nothing comes up on your screen and you just hear beeps
Jun 24, 2009 | HP Compaq Presario SR2011WM PC Desktop
NO POWER
If you have changed the power unit and the computer is still not powering up, then it is quite likely there is a motherboard fault - probably in the power management circuitry, which expects the power_good signal from the power unit at a precise moment in the boot up process. A fault in the power management circuitry would prevent the computer from beginning its boot-up process.
Do the fans in the power unit come on when the computer is switched on? If they don't - this suggests a power unit problem. If the power unit fans do start working but the computer still doesn't boot, this suggests either a faulty or 'dry' connection (easy checked) or a motherboard fault.
If your computer 'works' but nothing is displayed, try pressing Control+Alt+Delete. If it then boots up it suggests a power unit problem. If not .. we come back to the motherboard again.
A low wattage power unit can cause the problem you describe. Every 128 Mb of Ram needs 4 watts of power. Add more for the motherboard (up to 30 watts..) then the floppy/hard drive/dvd etc .. If the power unit can't supply the necessary wattage, it won't boot. The older 250-300 watt power units aren't suitable for modern computers with XP/Vista. Ideally, you should be looking at 400 watts plus -it will tell you on the power unit.
Though to be honest, it does sound like a motherboard fault.
The only other thing that can cause a computer not to boot up (though it will begin the boot up process) are other faults ... When you switch on does it actually display anything on the screen .. and are there any 'beeps'? 1 beep indicates everything is ok .. 3 short beeps and 1 long beep indicate a memory problem (and the computer won't boot..). 8 beeps indicate a video problem (and nothing will be dislayed on your screen). Same with 9 beeps .. which indicates a bios fault - and the computer won't continue the boot process.
If you have nothing .. no power whatsover ... it comes back to the power unit/mainboard. If you're happy that the new power unit you have put in is ok ... suspect the motherboard. If you have access to any unwanted or 2nd hand motherboard ... connect that. If your computer boots up ... its the original motherboard at fault.
Alternatively, rather than replace bits and pieces at random to cure the fault, take your computer along to a computer shop. It will take them minutes to test it for you and identify the fault.
May 17, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Not booting
listern to what ur beep codes say. one short-fine, one long & two short beeps-video failure, so on ... ... ...
May 02, 2009 | Dell Dimension C521 PC Desktop
My pc still won't boot up
The beeps are beep codes. Were they short or long? Also do you know who makes your BIOS?
Jul 26, 2007 | EliteGroup P4VMM2 Motherboard
Matsonic 8328E (MS8328E) Motherboard Logo
60 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
