Question about Garden
What type of oil do I add to the tb146 ec crank case, troy built cultivator, how do I know if there is enough?
    President:
  • 3,074 Answers
Oil is of a preference, I would use that same that you use in you car, fill it to the top of the bottom of the oil plug. Hope this helped Tim
Posted on May 22, 2011
Removing motor from body and blades to change a starter rope?
unscrew cover where recoil rope is and cover and recoiler come off dont have to remove anything else
Aug 02, 2016 | Troy-Bilt TB146 EC 4-Cycle Garden...
After it cranks and runs when you give it gas it dies
sounds like bad gas or carburetor issue. drain all gas out and put in fresh. if it has a bowl on the bottom of the carburetor take it off and see if there is water or dirt in there. if it looks really bad you may have to take the carburetor of and clean it. this should make it run like new.
Mar 24, 2016 | Troy-Bilt TB146 EC 4-Cycle Garden...
Replace pull cord
Easy to do - go to Utube and they have the instructional video on how to accomplish this. Hardest thing is to get the cord - Home depot only sells it in 50 foot lengths. But you can get a kit complete with handle for about five bucks same store.
Aug 31, 2015 | Troy-Bilt TB146 EC 4-Cycle Garden...
Warm up time on a Troy-Bilt cultivator
I have a Cub Cadet 4-cycle cultivator and it takes a while to warm up as well. I assume that is the norm for those small 4-cycle engines. But it should not take more than 3-5 minutes to warm up enough to go ahead and start tilling. Unless of course you live in a fairly cool climate. In that case it may take a little longer. I live in Tennessee.
May 09, 2015 | Troy-Bilt TB146 EC 4-Cycle Garden...
Rope pulls but does not trun motor
Recoil may be broken or seized up inside so it won`t work.
I had a lawn mower like that and tore the recoil off and had to repair the flippers inside. Mine had a broken pin.
Jun 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Which fuel line is the intake line at the carburetor?
The fuel line goes:
  1. From the filter in the tank to the carb, usually the bottom most connector.
  2. From the carb to the Primer. The tube in the center of the primer bulb.
  3. From the primer, outer tube to the fuel tank.
Get the manual online from Troy-bilt herehttp://www.troybilt.com/equipment/troybilt/tb146-ec-4-cycle-garden-cultivator
j
May 07, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
How to replace gas lines on the tb146ec cultivator.
Hi Robert:
Sounds like a matter of removing the old lines and installing new ones.
Work safe! Drain fuel from tank first.
May 03, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Tiller culivator just sits and digs doesnt move forward? how do I resolve this?
Push down a little on the handle so the tines are not as far in the ground and also push forward a little.
Apr 10, 2013 | Troy-Bilt TB146 EC 4-Cycle Garden...
Need an operator's manual for a tb146 ec tiller
I believe that the tb146 ec is a Troy-bilt tiller, so you need the model number and the serial number to get the manual. Go to http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Then enter the model and serial numbers and click Search.
The plaque with these numbers is usually on the outside of the tine housing. It's generally in a spot that won't get damaged while the unit is in use.
I hope this helps.
Jul 08, 2011 | Garden
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
