What do i use to clean the screen on my 52 inch tosiba regza LCD tv
  • 36 Answers
A slight damp cotton cloth, do not use any chemicals on the screen because it will marr the finish and cause you to have a bad image
Posted on Aug 15, 2008
I have tosiba regza 40 inch LCD....when we search channels able to get all and we save it...after a day all channels are lost n again we have to scan every day...power is never discontinued.
Main system control memory IC fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 19, 2015 | Regza Televison & Video
My 52" Toshiba Regza has a six inch vertical line just left of center that changes color as the picture changes. Some times it stays with the same pattern for quite a while. It goes away when I turn it off...
you must either change the t- con board, or the left board strip. it is dangerous because mines caught on fire. but most like since that strip is connected to the lcd screen u will have to replace the whole entire screen.
Aug 09, 2010 | Toshiba REGZA 52RV530U LCD TV
Toshiba regza 52xf550u has a 6 inch multi colored line in the middle of the screen...what is the problem
If it flickers and changes colors like my 52" did, I removed the back panel cover, tore off the cheap foil on top and removed the t-con board. Used a head gun as I seem to fix alot of things with it now adays since lead free solder is cheap, heat the points up for about 2 minutes, replace it and throw some air circulation. I also noticed the top of my lcd has two main boards the are supposed to match up a platic pin and slide into place, the boards were warped and wouldn't stay down. I used a dremel polishing wheel, cut it in half and wedged them down and tv is running clean again.
May 15, 2010 | Toshiba 52HL167 52 in. LCD HDTV
What is the best way to clean a toshiba regza 40" lcd tv screen? The blue towel that came with the tv just does not get prints and dust off.
Go to Amazon.com or Ebay.com.Buy a cloth call Micro Fiber Colthes best to clean LCD Screen.The cloth very find wolfven fiber well not easy leave any scratches in ur LCD Screen.
Jan 30, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My toshiba 52" screen was hit by a wii controller and the screen is distorted. Any advice?
It junk now,only good for now,it only use for electronics componnents parts.LCD Screen replaced will exeed the new tv.Tv companies well not sell out LCD screen cheap,90% the tv is the LCD Screen and it limited amount when they produce it.
Jan 28, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Have 52 inch toshiba regza tv black box appeared in top left corner will not go away tried changing channels still there
Check to see if the tv is in the text mode of the closed captioning.If not you may need a new main signal board.Also try unplugging the set for a couple of hours to reset it.
Nov 04, 2009 | Toshiba REGZA 52RV530U LCD TV
Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Jun 02, 2009 | Toshiba REGZA 47HL167 TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
