Question about Craftsman Garden
I have a craftsman mower model 917376722, bought used so no manual... trying to figure out if it is a 2 or 4 stroke engine so i put the right fuel in it
    President:
  • 3,074 Answers
If it has a place to add oil it is regular gas, if not then it is mixed. Tim
Posted on May 22, 2011
What engine oil do I use in my sit on mower
Nah 2 strokes for mixed fuel use a 5w30 unless its like a toro grounds master then you use 90 weight but yea 5w30 is what you want. If you live in a colder climate use 10w30
Apr 16, 2015 | Garden
Unable to start up CRAFTSMAN LAWN MOWER MODEL 917-377-190 Engine Model Number 143006700
Empty all fuel and put in some freshly bought fuel, does it try to fire? Have you looked at the plug after trying to start it? When did it last run?
Jul 21, 2014 | Garden
Do you put fuel additive in a MTD push mower?
Yes if you are talking about fuel stabiler on a four stroke fuel tank engine yes,,, and if you have a 2 stroke make sure you have right fuel and oil mix and yes u can put in stabilzer in a 2 stroke engine fuel tank
Joe
Sep 11, 2012 | Garden
Low RPM's
I know this is an old post but I figure maybe my solution will be found by someone else doing a Google search and it can help them. Hopefully, you've gotten yours fixed in the 10+ months since you asked this.
Anyway, if you remove the top plastic shield from the mower (two screws hold it in place, plus a small cover near the air filter that needs to be removed) you will see a small spring that attaches to a tab at the front of the mower. If you bend that tab forward it will put more tension on the spring and increase the engine speed. You'll know if you are looking at the correct spring if you lightly press on the spring and the engine speed increases.
It is a good idea to monitor the adjustment with a tachometer. My owner's manual says the engine has a 3,100 max rpm. You don't want to set it above the specified rpm or you'll probably burn the motor up in a short time. I set mine at 3,060 rpm. It's hard to get it perfect but I figured slightly low is better than too high. Mine had been running at 2,800 rpm.
I bought a small engine tach on eBay for around $9. The wire wraps around the spark plug wire 4-5 times and then you can read the engine speed. It also keeps track of how many hours the engine has been running. I figure that will come in handy for oil change intervals so I permanently mounted it to the mower. It almost looks like it came that way from the factory. :-)
Here's the tach I bought: Hour Meter Tachometer 2 & 4 Stroke Small Engine
Aug 26, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
What 2-stroke mix for a Snapper mower (Briggs & Stratton 6.5 HP)?
USE A 32:1 MIX. THE MORE THE RATIO OIL TO GAS MIX RATIO THE MORE COOLER AND LONGER LASTING THE ENGINE WILL BE. 40:1 IS FOR FULL OUT TROTTLE CHAIN SAWS ECT.
Mar 13, 2012 | Snapper Garden
What is the valve setting for 2004 18.5 HP briggs & stration intek ohv engine?
31C700 engine? (model number)
This is pretty generac for all of their engines as a general rule 0.004 - 0.006
From the service manual for the 31C700 engine:
ADJUST VALVES
1. Set No. 1 cylinder at 1/4" (6.4mm) past TDC, compression
stroke.
a. Adjust valves and check, Fig. 17.
Valve Clearance (cold) IN and EX .005" (0.13 mm)
b. Torque adjusting screws and jam nuts to 60 in. lbs.
(7.0 Nm).
2. Set No. 2 cylinder at TDC, compression stroke.
a. Repeat for No. 2 cylinder.
Thanks for choosing FixYa,
Kelly
Aug 24, 2011 | Craftsman Garden
I got hold of a sanli 350 lawn mower 4 stroke the people gave me a bottle of 2 stroke oil with the mower is this the right oil to use
No No No No!!! If your mower is definitely a 4 stroke then do NOT put 2 cycle engine oil in it (and I hope they didn't either). Drain out whatever's in there completely and put standard 30 wt. oil in there. Not 10W30, but straight 30 weight. Use synthetic even if you want longer engine life.
Aug 21, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
69 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
