Question about White Sewing 1418 Mechanical Sewing Machine
Does the bobbin on a white 1418 thread clockwise or counter-clockwise?
  • White Sewing Master
  • 1,129 Answers
You can download a manual from here http://www.singerco.com/accessories/manuals.html, just type in the model number and click on 'search' to locate your machine's one.
As a rule of thumb, the thread usually comes off a bobbin goes through the tension then reverses direction back the other way. So as you pull the thread, the bobbin usually turns anticlockwise. But always check the manual to be sure.
Posted on May 23, 2011
Threading correct way
My 7th grade home ec. teacher taught us that just about all machines thread the same: Spool, Thread guide, Thread guide, Tension, Take up lever, Thread guide, Thread Guide, Needle. I haven't come across a machine yet that hasn't followed these guidelines (the number of thread guides vary) If the thread make a "crow nest" under the fabric, your bobbin may be in backwards. Again, most machines the bobbin should turn COUNTER clockwise. To check, thread the bobbin and hold so you can see the direction it turns when the thread is pulled. It should spin counter clockwise. Still having problems, be sure the presser foot is down. Still a mess, then your machine my be one that turns clockwise.
Dec 16, 2012 | Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
I HAVE A 1418 MACHINE WHITES.. MY NEEDLE KEEPS GETTIN CAUGHT IN SOMETHING IN THE BOBBIN AND IT JAMS. WHAT AM I TO DO
put in a new needle
clean under the needle plate & bobbin area for loose threads & lint
make sure the bobbin is not warped
try a different thread
of the problem still happens, then it needs to be serviced
Aug 05, 2011 | White Sewing 1418 Mechanical Sewing...
The thread clicks when it goes around the bobbin and I have to stop sewing as it makes a big knot on the back of the fabric. I have cleaned out the bobbin case but it is still not sewing properly. It was...
Hello Supernana.
Check to see if you have your bobbin in upside down. If your machine requires it to unspool from one side having it spool from the other side (counter clockwise vs clockwise) can cause you problems like this. Your manual should tell the correct direction. My machine (Brother) for instance requires that the thread to pull counter clockwise direction.
Sylvia
Mar 17, 2011 | Elna Quilter's Dream 6003Q
After 3 or 4 stiches, the bobbin thread binds up in the lower mechanisim. I cant get the machine to stitch at all.
Either you are putting the bobbin in backwards. The thread should come off counter clockwise or the tension on the bobbin in too loose. I have done both several times in my lifetime.
Jan 07, 2011 | White Sewing 1418 Mechanical Sewing...
Have been trying to adjust the bobbin pick up and seem to get that part the the thread gets caught in the bobbin mech or knots up on material
try to rethread top and bottom, and make sure the thread is seated in the top tension disc. I have owned a few Whites and had a lot of timing issues with them
Aug 14, 2010 | White Sewing 1418 Mechanical Sewing...
MY MODEL IS 1418 AND THE BOBBIN THREAD KEEPS CATCHING AND BUNTCHES UP.
open up the bobbin carry clean out all the dust and lint remove the whole bobbin carry the 2 blk switch on the sides this should take care of problem and check that are on right setting... Good luck
Jan 07, 2010 | White Sewing 1418 Mechanical Sewing...
My white thread from bobbin shows thru embroidery
flip your bobbin
when I hold my bobbib in my right hand and pull the thread with my left hand the bobbin spins counter clockwise, this is how i put it in the machine
Do you wind your own bobbins if so make sure you wind evenly
I order a box of 100 pre wound bobbins from Brother
Sep 10, 2009 | Baby Lock Esante
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
White Sewing 1418 Mechanical Sewing Machine Logo
177 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
