Question about Refrigerators
Find compressor S51C90JAU6 - Refrigerators
  • 594 Answers
Are you needing to find the compressor on your fridge or a replacement?
Posted on Aug 15, 2008
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    3.9 V6. How can I remove the A/C clutch?
    You need special tool
    Tools Required ?€¢
    J 37872 Compressor Clutch Holding Tool
    J 6083 Snap Ring Pliers
    Important: Remove the three adjustable dowels from the J37872 Compressor Clutch Holding Tool.
    Install three 5/16 x 1 inch bolts in place of the dowels.
    Remove and discard the compressor clutch plate bolt.
    Use the J 37872 to hold the compressor clutch plate from turning.
    Remove the compressor clutch plate from the compressor.
    Remove the compressor pulley snap ring using the J 6083
    Remove the compressor pulley from the compressor.
    Remove the compressor clutch coil snap ring using the J 6083 .
    Remove the compressor clutch coil from the compressor.
    google J 37872 - to see tool !
    Jan 31, 2016 | 2006 Chevrolet Chevrolet Impala LT
    I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
    http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
    Devair/DeVilbiss Piston Air Compressors
    www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
    10HP 4 Cylinder 2 Stage Air Compressor Pump
    https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
    Petstar 4 - Ingersoll Rand
    www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
    Jan 31, 2016 | Air Tools & Compressors
    Motor turns and pump pully does not. burning up belt.
    Air Compressor Trouble-Shooting, Problems, The Causes ...
    www.portlandcompressor.com/compressor/trouble-shooting.aspx
    Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
    Reasons Why an Air Compressor Will Not Build Pressure
    fix-my-compressor.com/compressor-will-not-build-pressure/
    An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
    Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
    www.sawmillcreek.org > ... > General Woodworking and Power Tools
    Mar 16, 2006 - 15 posts - ‎8 authors
    I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
    Jan 05, 2016 | Ingersoll Air Tools & Compressors
    How do you get ac compressor out without taking engine out 2006 buick rainier
    COMPRESSOR REPLACEMENT
    REMOVAL PROCEDURE
    1. Recover the refrigerant Refer to Refrigerant Recovery and Recharging.
    2. Remove the washer solvent container.
    3. Remove the air cleaner resonator outlet duct.
    4. Remove the cooling fan and shroud.
    5. Remove the accessory drive belt from the A/C compressor.
    1. Remove the compressor hose assembly nut from the compressor.
    2. Remove the compressor hose assembly from the compressor.
    IMPORTANT: Remove and discard the sealing washers.
    1. Remove the upper A/C compressor mounting bracket bolts.
    2. Remove the lower coolant hose.
    3. Raise and support the vehicle. Refer to Vehicle Lifting.
    4. Disconnect the A/C compressor electrical connector.
    5. Remove the lower A/C compressor mounting bracket bolts (3).
    6. Lower the vehicle.
    7. Reposition the compressor and mounting bracket to access the remaining compressor to bracket bolts.
    8. Remove the upper A/C compressor mounting bolts (4).
    9. Remove the A/C compressor.
    10. Remove the A/C compressor bracket.
    Aug 25, 2013 | Air Conditioning and Heat for Buick...
    Compressor not coming on check red wire on compressor with test light compressor comes on pressure good high and low air cold
    If the compressor came on when you were testing it with a test light, it sounds like something is wrong with your ground for your compressor, and completely the circuit through your test light.
    Jul 01, 2011 | 2003 Honda Civic
    Refrigerator still makes clicking sound and does not cool after bad start relay was replaced
    Couple Video How To Replace Compressors. I Think Its Not DIY.
    Hope Thats Helps.
    Aug 12, 2009 | Refrigerators
    Please help our ac compressor wont come on
    Hi, did you change, capacitor for compressor too. check compressor overload switch,(relay) normally located on compressor terminals, (where you connect wires to compressor) that's the device that goes klix when compressor goes to start, could be faulty, or maybe low voltage from your mains(house panel) check line voltage, with digital volt meter, some compressor won't start if voltage drops to low, yes fan will work, could also be, your compressor has a lock rotor, (hard start), you can buy a compressor hard start kit, from appliance store, and try to start compressor, or maybe compressor internal winding, are damage, especially now in summer, when you got a lots of voltage drops, check compressor winding, check compressor winding for short circuit, remove cover on compressor, remove 3 wires from compressor terminal, use ohm meter, put one tester lead on copper tubing that's connected to compressor, and next lead to compressor terminal, one by one, if you get beep (continuity) from anyone of those compressor terminal, you got a short- circuit in compressor, you will have to replace compressor, but if there's no short, them try hard- start kit, replace overload relay, you will see it at compressor terminal location, after you remove cover. good luck.
    Aug 10, 2009 | Heating & Cooling
    Compressor
    Unfortunately, the cost to replace just the compressor unit is not much different than replaceing the entire unit.
    May 29, 2009 | Alton Alton 3 HP Air Compressor
    Refrigerators Logo
    227 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
