Question about Intex "" Metal Frame Pool Set (56998e) 56998e
My pool is leaking where the sides are joined to the bottom how do i repair this leak
    Guru:
  • 679 Answers
Hi
You don't have much choice in the matter. Either find and repair the leaks using a proper vinyl patch kit with underwater glue ( you can get this at your pool shop) or buy and install a new liner.
Thanks for using Fixya.
Posted on May 22, 2011
Do I remove the wood side panels to fix a leak in a dimension one spa or go from the bottom?
in most cases, the sides of the spa are removable to fix leaks and service the unit. going from the bottom will not give you access to anything important
Nov 04, 2015 | Pool & Spa
How do I stop my swimming pool from leaking water?
id look 4 a leak someplace in the suction side of things when pump runs it draws air in hole so No leak but when pump shuts off No draw just water and it leaks out
look for hairline cracks in skimmer bottom and bottom suction lines , Might require scuwba equipent to see ?
Nov 03, 2014 | Pool & Spa
Repair multiple leaks in INTEX Pool bottom
need more info are you able to drain pool? if so coat with water sealant paint
Feb 15, 2014 | Intex Pool & Spa
Hayward sand s166t. leaking from bottom
Are you sure it is leaking from a spot "Originating" at the bottom? Many times this is what is seen, but the water is actually traveling down the side.
If at the bottom, you either have a cracked tank, or the drain cap is loose, missing the cap gasket or it is on "Cross Threaded"?
But... most likely from experience, it leaking at the valve clamp.
Nov 17, 2012 | Hayward S166T Pool Filter System w1 HP...
My 14' pool is leaking from the bottom slowly. 1" per 26hrs. I can not find a hole. No water on the sides of the pool. It is leaking out from under it. How do I find the hole. I have patched holes...
Using goggles I inspect the bottom and looking at each individual speck on the bottom. Sometimes what looks like debris is actually a hole though it seems it would take a good size hole to leak that much. Check the seam by gently trying to spread it.
Jun 14, 2011 | Intex Easy Set Pool 15x36
Heater is leaking
Close all pool drain valves, also all return valves. This will stop any water being sucked out of pool.
Jul 24, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Leaking sunglo solar pool panels
I used to work at Sunglo. I am not sure how to repair but i can tell you how the panels were made. This may help you determine how to repair.
Each panel is made up of indivdual strips that have been extruded. The indivual strips are joined together to form the panel. Each strip has approx 8 or 10 internal and independent channels to facilitate the water flow. If one of these is leaking you should be able to repair with by sealing the hole with heat. If you seal the top part of the panel nothing will flow through to the bottom.
Aug 20, 2009 | Sunglo Black Portable Liquid Propane Gas...
Low pump pressure
Or blocked.
Have you used pool 'O' ring grease on all 'O'rings - tipped water from bucket on all pipe joins on suction side to see if blows bubbles?
Jul 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
My hayward superpump for the pool in leaking
normally this is not a crack in the housing. It is usually a shaft seal.
David
May 14, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Intex "" Metal Frame Pool Set (56998e) 56998e Logo
236 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
