Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Copying file I went to copy te file to usb and it said i did not have permission to do this to see the administrator??? It's my file , my computer, my flash drive???
  • 876 Answers
Does more than one person use your computer and do you have separate identities. When you sign on, do you choose your identity? You will need to go to
start
control panel
user accounts and see who the administrator is
Changes can be made here, but the administrator has to make them
Good luck.
Posted on Aug 15, 2008
SOURCE:
My toshiba external harddish slow working small file only copy large fill donot copy
Is there enough free space on the drive you're copying to? Check also that you have administrator permission for the file you want to copy. Is the 2tb partitioned or any part of it write protected?
Oct 15, 2016 | Toshiba Computers & Internet
How can I get permission to copy file from computer to my external hard drive
You should be able to copy and paste, or simply drag the file to the external hard drive (to make a copy).
Right click on the file, then select 'Copy'. Navigate to your external hard drive and then click 'Paste' to copy the file into it.
If you're talking about something like a word document you may have to change the permissions. To change the permissions right click on the file and then choose PROPERTIES. Change the properties if need be (the permissions..)
The image below is from my computer using Linux .. however the process is the same using Windows. Right click the file .. then choose Properties..
Jan 05, 2016 | Hard Computers & Internet
Can't transfer mp3 files to usb jump drive or delete the saved mp3 files
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hop this helps
Oct 23, 2012 | Generic Memory USB 2.0 128MB Black Pen...
My 8 gig memory stick pro due cannot copy any file it says cannot copy eboot pls help?
Click permissions
then you might restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
Aug 12, 2012 | Electronics - Others
Usb flash drive v30 TS2GJFV30 files are not stored even copying process normal
Click permissions
hope it helps
Jun 28, 2012 | Electronics - Others
Cant delete any file aND copy any file as well
click start click to open on my computer you should see your transcend usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Click permissions
hope this helps you
Jan 06, 2012 | Transcend StoreJet Electronics - Others
Hi, I'm having problem opening my backup file from my USB that I copy from my old laptop to my new laptop. When I try to open the back up file their is an error saying: unable to open file. file maybe...
you need to to take ownership of a file or a folder then copy them over
How to take ownership of a fileYou must have ownership of a protected file in order to access it. If another user has restricted access and you are the computer administrator, you can access the file by taking ownership.
To take ownership of a file, follow these steps:
  1. Right-click the file that you want to take ownership of, and then click Properties.
  2. Click the Security tab, and then click OK on the Security message (if one appears).
  3. Click Advanced, and then click the Owner tab.
  4. In the Name list, click Administrator, or click the Administrators group, and then click OK.
    The administrator or the administrators group now owns the file.
To change the permissions on the file that you now own, follow these steps:
  1. Click Add.
  2. In the Enter the object names to select (examples) list, type the user or group account that you want to have access to the file. For example, type Administrator.
  3. Click OK.
  4. In the Group or user names list, click the account that you want, and then select the check boxes of the permissions that you want to assign that user.
  5. When you are finished assigning permissions, click OK.
  6. You can now access the file.
How to take ownership of a folderYou must have ownership of a protected folder in order to access it. If another user has restricted access and you are the computer administrator, you can access the folder by taking ownership.
To take ownership of a folder, follow these steps:
  1. Right-click the folder that you want to take ownership of, and then click Properties.
  4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of the folder, select the Replace owner on subcontainers and objects check box.
  5. Click OK, and then click Yes when you receive the following message: You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?All permissions will be replaced if you click Yes.
    Note folder name is the name of the folder that you want to take ownership of.
  6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
Nov 04, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
When I plug in my sandisk cruzer micro 4gb, the option to opend it directly open up pictures, music, open the folder directly, etc. pops up and I exit out of that. Then when I go to my computer, the U3...
Copy all the data-files from the USB device to your 'C:' drive.
Then, delete all the files from the E: and F: drive.
Be sure to select/delete all the "hidden" files.
Now, your USB drive is back to its "factory" status.
Nov 16, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have Windows 7 & Can't copy from USB
Hello
Ok, here is how you fix this. Go to the folder which you are copying from, right click and go to properties. Security, advanced, change permitions, now click on your name in the box and check of the box at the bottom. There should be a pop up directly after this. Now it should work fine.
Kind regards
Andrea
Nov 07, 2009 | Electronics - Others
Cant access files...
Boot up into safe mode, logging in as the Administrator, not your account.
Go into the security settings for the folder and change the permissions. The easiest thing would be to give Everyone full access. Don't forget to promulgate the permissions to the directory tree as well.
Good luck
God Bless
-Carlos:
Jun 20, 2009 | Gateway 310 Series (158920) PC Desktop
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
29 people viewed this question
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
