Question about Schumacher 10 Amp Fully Automatic/Manual Charger by
Needle jumps back an forth between charging and charged.
  • 843 Answers
Did you try it on a different battery? These automatic chargers won't charge unless they detect a little bit of voltage and not a direct short. Your battery might be shorted out. Good luck, Al K
Posted on May 22, 2011
Battery went dead so I jumped it with a power pack 350 amp. It starts but runs rough and eventually dies and all lights flash and speedometer needle jumps back and forth.
Sound like your alternator is shot. Do the test ..After you charge the batery or get it boosted if you remove the positive battery post OFF the battery and the engine dies right away your alternator if shot .
Mar 02, 2016 | Cars & Trucks
I tried to charge my car battery with a Chicago Electric charger model 66783. I followed the directions for charging the battery in the vehicle. After selecting the charge rate of 10 AMPs, the ammeter...
Relax, the charger is working fine. What it is doing is charging the battery to 15.5V. During this time, the "charge complete" LED is off, and the current meter shows the needle going to the right. When 15.5 volts is reached, the current is shut off, the needle goes back to the left, and the LED goes on. When the battery voltage drops to 13 volts, the current goes on again, etc. At the beginning, with a very depleted battery, the needle will be towards the right, then as the battery gets charged close to full capacity, the needle will bounce back and forth because the charger is feeding current in short pulses. Towards the very end of charging, the needle will stay longer and longer at the left end (the LED will be ON), and spend less and less time to the right (LED will be ON for longer periods, and "blink" OFF less and less). Finally, at full charge, the LED will stay ON, the needle won't make excursions to the right, etc.
Dec 29, 2009 | Chevrolet Classic Cars & Trucks
Our batery gauge jumped back and forth an nowe batery si dead will start with jump.alt si only 10 mounths old.could it be anneything els?
alternator's go bad - even some new ones are no good - prolly a rebuilt one gone bad - test it -- charge the battery - - then drive it in the day time to the local advance or auto zone - they will test ur charging system - also - take down the vin number and ask the local dealer if there have been any recalls or service bulletins - on ur car -
Dec 27, 2009 | 1990 Plymouth Acclaim
Charging gauge bouncing back and forth starts after jump
sounds like a shorted field in the alternator
Nov 07, 2009 | 1981 Ford F 150
My 600amp jump pack needle hasn't been charged in a while
Have a look at one like yours in store & see what specs are on plug in to charge. It will say Output voltage ..., then how many amps, or milli-amps, for example: ( output voltage 13.5 VDC @ 800ma.) Now find a charger/adapter, with same specs, and plug. Perhaps one your using is very minimal output, or lower voltage. Be sure polarity symbol is same on both too.
Jul 24, 2009 | 1999 Suzuki Vitara
The needle on the needle keeps jumping up and doun and doesnt seem to be charging.
It sounds like a defective alternator regulator, stator, or diode trio. Its probally better to get a rebuilt alternator.
May 22, 2009 | 1999 Pontiac Grand Am GT
Battert problem
This would typically indicate a charging system or cable connection problem. Take your vehicle to a local Interstate dealer to have the charging system, cables, connections and battery tested. This will help determine what type of problem you are having.
Nov 20, 2008 | 2006 Harley Davidson FXDI Dyna Super Glide
Schumacher 10 Amp Fully Automatic/Manual Charger by Logo
647 people viewed this question
Top Schumacher Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Schumacher Hardware and Accessory Expert? Answer questions, earn points and help others
