Try uninstalling a few
unnecessary programs then click start run type cmd then
type chkdsk/r/f which will scan for and attempt to fix any bad sectors and
automatically fix any corrupt files on your hard drive this will schedule on a
restart then defragment your hard drive or
click start control panel
administrive tools,computer management ,disk management right click on your
drive select properties click tools you should see click check now click start
tick in both boxes automatically fix files and scan for and attempt recovery of
bad sectors place then a tick in both boxes then select check now,start should
schedule this task when restart
do not do anything while
the chkdsk utility is in progress any input may damage your computer
then you should test or replace
all leads make sure they are securely seated and are not bad/faulty that are
attached to your (((motherboard to your
hard drive)))
then click start all
programs accessories system tools defragment your hard drive
you might have to install
more RAM random access memory to check how much ram you have
to check the details on
your computer
click start all programs
accessories system tools system imformation you will see all of your computers
imformation from there another way of doing this
click start right click on
my computer select properties you will see all imformation about your computer
including installed ram
scroll to the bottom
toolbar (bottom of screen) right click you can select task manager applications
also processes you will see whats running on your computer if you see something
running that you don
