Does the receiver have a 'mono' button that converts the output to mono? Thank you.
    Brigadier General:
  • 8,546 Answers
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
Or try Google images for a picture
Posted on May 22, 2011
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
Why is my deck not controlling my subwoofer level?
If your Sony receiver has a separate sub output, it probably has a fixed level for application to a powered sub. Your mono amp can only boost the fixed signal level it receives from your receiver. The receiver can't drive that mono amp harder
Jun 05, 2013 | Sony MEXBT5700U CD Receiver Bluetooth...
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Cant find bluetooth on my kenwood kdc-w3537
it is a button on the remote half way down the left side it has a small picture of a phone next to the button you have to press, and are they pared, good look
Apr 11, 2012 | Car Audio & Video
Hi, How do I connect a powered subwoover to my PMP 6000 when i have connected 1 pairs of passive speakers to Output B and 1 pair of passive monitors to Output A . Ampmode switch set to Monq1 and Mono...
hi,
this mixer has output's from cd/tape(rca plug) that can be used to connect an additional amp for output to a sub. It is designed to use for recording but may also server as a pre-amp output to an external amp of choice.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 26, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
My remote broke and some of my channels are on sap. and when i go to the menu there is no audio setting how do i put the channel setting back to stereo or mono
Hello
While receiving an MTS broadcast, press [Audio] repeatedly to to cycle through the available channel.
Main: Outputs main audio.
SAP: output secondary audio programme.
Mono: Outputs mono audio.
You must ahve remote control to change these, because only remote control have Audio button on it to control these. OK.
May 05, 2011 | Sylvania LC-155SL8P 15 in. LCD Television
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer Connection: Speaker wire to Mono RCA
    The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
    1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
    2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
    3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
    4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
    You can even now turn off your subwoofer / adjust the volume easily now!
    Oct 30, 2007 | Audio Players & Recorders
    27 people viewed this question
     Grubhead
    Grubhead
