Question about Amana Heating & Cooling
Have amana heat pump ac unit,,condenser fan doesn,t turn when on, not cooling, makes humming noise
    Problem Solver:
  • 12 Answers
The fan needs to be cleaned and lubbed. If this cannot be done then replace the fan.
Posted on May 22, 2011
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
I have an older amana central ac/heating unit, fan not turning outside, did pencil test, turns slowly then stops. changed capacitor a month or so ago all was fine. started making a humming noise so ran and...
Sounds like the fan motor has reached its endpoint. It will have to be removed and replaced. Find the dircuit breaker in your electric panel that supplies power to the air conditioner unit. When you have found the right one, even the humming sounds will be absent. The fan usually is at the top of the unit. You must have opened this to change the capacitor. Remove the fan band motor as a unit and take it to a store like Grangers and determine if they have a motor that would replace the one from your unit. If the motor has a model number on it, you may find a replacement available onlilne by Googling that number and the name Amana. Put electricians tape over the wires that led to the motor, just in case someone turns on the circuit breaker before you have completed the job
Oct 04, 2013 | Goodman CLQ36AR49 Air Conditioner
PTC073E35AXXX humming
sounds like a control transformer . No danger.
Nov 20, 2012 | Amana PTH123B25AJ Heat Pump Air...
Refrigerator not cooling...makes hissing noise
From your problem description I would say it sounds like maybe the condenser fan is not running. If that fan does not run, the compressor will overheat, and get very unhappy, LOUDLY. There is a fiberboard cover on the back of the unit, unplug the unit, remove the cover and inspect the fan, it should turn freely if you nudge it with your finger. If it does not turn freely, you will need to make it so by lube, removing foreign object (dead mouse once for me) dust dragons etc... or replace the fan if necessary.
Dec 16, 2009 | Amana Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
2 problems.. AC Comp cuts out. And Fan will not stop.
Unit#2 -Sounds like the contacts on the master switch are welded closed or the switch is broken, Replacing the switch should fix this unit.
#1 is a little more difficult to diagnose. The compressor is being taken off line by a circuit that protects the compressor from damage either; 1- liquid refrigerant getting back to the compressor which can be caused by something as simple as a clogged return air filter or evaporator coil on a heat pump or 2- overload situation caused by a bad condenser motor or a clogged condenser coil. The first thing you need to do is clean both coils and replace the filter,. Then check to be sure your getting good airflow across both coils. I think it's most likely an airflow issue I hope this resolves the problem GL!
Jun 11, 2008 | Amana PTH123B25AJ Heat Pump Air...
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Heating & Cooling Logo
179 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
