Question about Dishwashers
Bosch SGS43T52GB not draining at the end of a cycle. Is it the pump? How easy is it to change the pump?
  • 213 Answers
SOURCE: Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Posted on Nov 20, 2007
COXY
  • 76 Answers
SOURCE: BOSCH DISHWASHER SGS 6312GB/13 , FD 7810
You have a leak underneath and it is switching the anti flood switch on. Tip the dish washer back at a 45 deg angle, you will probably get water teak out the back, stand it back upright and try it. although it will probably work you will need to look underneath and find where the leak is coming from, my guess is its the wash pump and will cost around 100 pound for an engineer to repair.
Posted on Dec 03, 2007
SOURCE: Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
Thanks for the input Dicky...I think my dad will be onto the place of purchase first thing tomorrow!!
Posted on Jul 13, 2008
mastatech
  • 478 Answers
SOURCE: Bosch SHV46C
Replace the fill valve that sound is it trying to open
Posted on Mar 12, 2009
Macmarkus
  • 2605 Answers
SOURCE: My Bosch shu3307uc pumps out all the water at the
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch SHU3307UC dishwasher, correct ? Firther to this you.ve stated "slowly fills the bottom between cycles, even with little or no activity at the sink"
It sounds to me like the fill valve is at fault unfortunately. This is a very common problem for Bosch dishwashers of that era.
A faulty fill valve...sticking in the "open" position either due to the plunger in the coil getting stuck or sediment inside the valve body impeding it from closing correctly...Either way you're safer to change it with the history of these valves failing.
This is what to look for...
As long as your model is indeed a Bosch, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance. Thanks for choosing FixYa and good luck.
Please take a moment to rate the assistance provided here and a brief testimony on your experience here at FixYa is appreciated as well and tell your friends to look for "Macmarkus" on FixYa should they need asistance as well.
Regards,
Macmarkus :)
Posted on Sep 27, 2011
Testimonial: "The fix was easy and exactly as described, and works perfectly! Thank you very much! If you need any car advice, look me up, I will be glad to help! Bob"
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
Jul 18, 2011 | Bosch Washing Machines
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Aug 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher doesn't pump the water out at the end of the cycle.
clog in the unit . check the drain hose. disconnect the hose then drain machineinto bucket. then check the drain pump to see if the pump is pumping or clogged.
Mar 13, 2010 | Bosch Dishwashers
At the end of the cycle the water is not draining out of the tub. I vac'ed out the water, removed the filters and checked for debris but found non.
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
May 06, 2009 | Bosch SHV46C03 Built-in Dishwasher
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
