Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hp 7310 all in one will not scan. installed drivers repeatedly, when you click scan, scanner gets ready to go and then just hangs
  • 3 more comments
  • ninatgomez May 22, 2011
    If it is faulty, why does it work perfectly with Windows fax and scan?
    I was told to reboot my computer and re-attach the USB for my HP7310 but scanner is still not working. When I try to install drivers, it is saying that all drivers are installed. The scanner works well with Microsoft Fax and Scan but not HP Solution center
    Mine is a new Lenovo with Windows 7 64 bit
    You gave me material to read for Vista. Mine is a Windows 7 64 bit.
  • ninatgomez May 23, 2011
    I uninstalled and reinstalled the HP All in One with all of its drivers. Yes, I did indicate 64 bit. When I do the diagnostic, everything is OK except for the HP Twain Driver. It is saying it is used by something else. I am trying to figure it out - do you think I should delete Microsoft Fax and Scan because maybe it is confusing the driver?
    I also did what you said - turn off, reboot, etc. It didnt work so I just reinstalled everything. Looks better except for the Twain issue
    Guru:
  • 1,833 Answers
According to your problem, you need to check the scanner status first. Check the scanner roller and light are moving properly while scanner is on work. If there is any problem then you have to repair it, may you have to change the scanner roller. You can test the scanner from scanner and camera wizard in control panel. If any fault in scanner then it will be shown in this wizard. You can try fresh reinstall of the driver after removing all drivers and other component of the printer. And after installation reboot the system and the printer both.
Posted on May 23, 2011
  • 10,319 Answers
    Guru:
  • 610 Answers
If you are sure that you have installed the right driver for your device, then this is definitely a sign of a faulty scanner. You can have it replaced if it is under warranty.
I've had the same problem with my own HP scanner, and the workaround I usually do, is to unplug the usb and reboot my computer. Then plug the usb back and let my pc detect my scanner. It would usually work after doing that but will do the same problem again eventually.
Hope this helps.
Posted on May 22, 2011
  • Christopher Ian Tecson
    Christopher Ian Tecson May 23, 2011
    As i have told you, this is if you are sure that you have installed the right drivers. You are using windows 7 64 bit, have you installed a 64bit driver for the scanner?
    Do you have any other printer installed? You can try removing the Microsoft Fax and Scan as it cna be the reason why the twain driver is flagging it is being used by another process. Make sure you do the reboot after removing so changes can apply.
I having hp scanjet 8350 scanner+adf its not scanning and automatic document function also not working but when i disconnect the adf /tma cable the flatbed scanner start working perfectly but again when i...
Thank you for writing a complete question that we are able to understand. It's nice to see a well worded question on here for a change.
To answer your question, this sounds like either a driver or firmware problem with the scanner. You can download the latest driver for your scanner from the HP support site here (click here) and download the available firmware upgrade for your scanner as well from the same location.
I would check to make sure that you have the latest driver first, and install that first if you do not. Then I would install the firmware upgrade immediately after, since it seems to fix the error that you are experiencing:
"Scanner hangs and does not respond when scanning many pages from the flatbed."
Good luck and thanks again for the well worded question!
Feb 13, 2012 | HP Scanjet 8350 Flatbed Scanner
I'm trying to scan a document, but the computer I want it to go to is not on the list. Also the computer is not recognizing the printer as also a scanner. The printer is an HP OfficeJet 7310...
is the solution center or hp director installed on the pc? look under add/remove and check if it's included in the list of programs installed. if it is there,look for it's icon on the desktop or click on start,all programs,hp folder,hp director and hp solution center.launch it from there.use it to scan from your computer.check for error messages and let me know.
if it is not installed ,you may need the disk to install it.or go to hp.com and click on support and drivers to download the latest version of the printer software.
May 27, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Hp7310 not scanning when using HP Solution Center. Scanner works well with Microsoft Windows Fax and Scan. I have repeatedly installed HP drivers.
May i know the computer operating system and do you receive any error messages while attempting to scan via Solution center?
May 22, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Need help in troubleshooting scanner problems for HP 7310xi. My scanner doesn't work at all. When I hit the 'scan to' button, the display reads "You need to install or run HP software for this...
Take the program completely out and restart computer. Install it again and install completely with out leaving any software programs out. You do have cd? If not go to hp.com and click on support for drivers and download them again. Make sure you have correct operating system checked. 32 bit is different than 64 bit....xp/vista..etc
Jan 03, 2011 | HP OfficeJet 7310 All-In-One InkJet...
My program for Officejet 7310 all in one is installed but whenever I try to scan, I get a message that the software needs to be installed. What do I do?
Try going to Hp soltions for updated drivers. Also windows has it own scanning drivers. Try going to control panel and selecting scanner devices, and go through the installation wizard to install a scaning device, if your scanner is not listed then just click on install new device.
Oct 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
Oct 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
No scan options msg when I try to scan
I need to find the scanning software for hp 7310. It use to work, I had to reload everything and now I cannot get it to work
Nov 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner problem
I understand that you are receiving the error to install the All-i n-one software while scanning from the printer front panel.
You have not informed whether the unit is connected in network or with USB cable.
However, follow the below given instructions to resolve the issue.
Verify that the communication between the computer and the printer is fine and the full version All-in-one software is installed in the computer.
Solution one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running for the scan to feature to function. The Digital Imaging Monitor normally displays in the system tray in the bottom-right corner of the computer screen, which is next to the time. The Digital Imaging Monitor is ready when a check mark displays on the icon. This can take some time after startup to complete the initialization and for the check mark to display on the icon. If the Digital Imaging Monitor displays in the system tray, proceed to Solution two - Populate the destination list . Search for the file " hpqtra08 " in your computer and run the file. Solution two: Populate the destination list Here are the steps to set the scan options: 1. Open the HP Solution Center. 2. Click Settings. 3. Click Scan Settings and Preferences. 4. Click Scan to… Setup. 5. Click the Destination List tab. 6. If the Front Panel Destination List is empty, this is the reason the All-in-One is generating the error message, and you should continue with this procedure. 7. Click each program that you want to display in the scan to list. 8. Click the Add arrow. 9. Click OK. This should resolve the issue that you are experiencing with. Regards, Lawrence
Jan 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanning
For scanning Problem, reload the Driver as i mentioned below.
1.Click start - >run then type "twain_32" click OK.
2.A window will open and click EDIT menu-> select all, then delete all the files and folders.
3.Click start - >run then type "services.msc" click OK.
4.Look for service called "HPZ PML Driver", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
5.Right click on "HPZ PML Driver" and click "Restart".Close the window.Click start - >run then type "%temp%" click OK.A window will open and click EDIT menu-> select all, then delete all the files and folders.If u cant delete them its ok, just close the window and go to step 6.
6.Disconnect the Printer USB cable, Insert the installation disk of your printer.If Installation wizard pops up, click on cancel/exit.
7.open My Computer, right click on your CD/DVD ROM Drive , then click "open".Look for folder called "UTIL" then look for folder called "CCC".There you will see a file that says "Uninstall_2". Double click on that file.
8.A run box will poppup, click OK, now you will see the command windows, hit enter the Driver that is necessary for comunication which are corrupted will be removed.
9.After that, restart the PC and Insert the Disk and install the printer.Connect the Printer USB only if the PC prompts you to connect.After installaton completes, check the scanner.
I would appreciate your response if u reply me the status.
Thank You
Dec 09, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
