Question about Refrigerators
Igniter does not stop clicking after lighting gas on thetford fridge in motorhome
22yooper
  • 828 Answers
SOURCE: Thetford Fridge N112
There is a very likely possibility that the resistance heater for the 12 Volt side of the operation is open. This heater can be checked for continuity using an OHM meter from the terminals for the 12 volt .
Posted on Jun 02, 2008
  • 51 Answers
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Posted on Sep 07, 2008
  • 51 Answers
SOURCE: We have a Thetford N80
Try manually lighting the pilot when it is clicking. If it lights you need a new thermo couple let us know what you find out from this step
Posted on Sep 08, 2008
  • 68 Answers
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Posted on Mar 30, 2009
Healeyman
  • 1198 Answers
SOURCE: fridge will not work on gas
If you're sure the gas is igniting and making heat, you may have lost your refrigerant. It probably is ammonia, which smells very strong. Check your dealer for someone who can check it out.
Posted on Apr 27, 2009
Gas igniter on N604 3F fridge does not ignite gas, how do I fix this. Thanks
when starting on Lp does board click or light on board lite up see if voltage to ignitor if no voltage bad board if voltage to ignitor bad ignitor if lites check burn tube
Jun 30, 2014 | Thetford Refrigerators
I have a thetford N80 fridge fitted in my motorhome that pops the rcd until I cool it down using gas
it is drawing too much current and is a fire risk
there is a live wire touching the metal frame or the motor has locked up.
the rcd is saving you from having a fire or being electrocuted
can you find a local dealer who can diagnose/repair?
Sep 27, 2013 | Thetford Porta Potti 550P MSD
Fridge worked fine last camping season, this year light comes on in the fridge in AC mode, but won't get cold. It is a 3 way fridge in our motorhome, and we have always used it in electric mode only. I...
Also keep in mind that these units are very sensitive to being leveled; even a minor tilt will cause them to quit cooling. These units are not equipped with compressors as are home refrigerators which are not quite as fussy as the evaporative type.
Aug 04, 2011 | Thetford Norcold RV Cooler/Freezer
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
I have a freezer that does not work it clicks on for a few sec then cuts off what could be wrong
The clicking is the electronic ignitor trying to light the gas.
Either it's not getting any gas to light , or the flame sensor is not telling the computer that there is flame , so it shuts down the gas.
Most fridges have a small shut off right at the gas valve in the back of the fridge , it might be turned off. Put your ear up to the back cover of the fridge , if you hear it sparking and then you hear flame but it goes out after a few seconds , than it is the flame sensor. If you never hear the flame blowing , than it is not getting gas. Could be several different reasons. If you have disconected your tanks , maybe the gas has just not made it to the fridge yet. Newer ignitors try 3 times and then shut down if no flame is detected. Old ones only try once.
Apr 27, 2010 | Thetford Norcold RV Cooler/Freezer
Carbon monoxide into motorhome when using fridge
Check vent panels, on outside, as well as any roof vent for fridge to make sure no obstructions, that would stop the flow of fumes from flame, as well as check the flame on burner is nice and blue, and not orange, indicating rich mixture, which causes excessive fumes.
Apr 26, 2010 | Thetford Porta Potti
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Fridge will not work on gas
Apr 27, 2009 | Refrigerators
We have a Thetford N80 fridge in the caravn which will not light on gas. It clicks but no flame appears.
Aug 17, 2008 | Thetford Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
