Question about Mitsubishi LT-40133 40 in. LCD HDTV
I have multiple color vertical lines when i turn on my old Mitsubishi LCD HDTV. After about 20 minutes, they go away. But until then i can't see the left half of my picture, doesn't matter if it is my directv, dvd player or laptop source. it happens with all of them. how do i fix this and how much will it cost me? I don't know the model at the moment because i am not home to look.
    President:
  • Mitsubishi Master
  • 749 Answers
There are two possibilities - bad T-CON board and bad LCD.
In the first case you need a new T-CON in the second - a new TV.
it is usually the LCD and it's usually caused by overheating and detachment of the very delicate LCD with multiple tracks from the board that makes connection with the T-CON board.
It starts working after it heats up because all materials expand as temperature raises and that helps contact a place that was previously melted and detatched. We're talking micrometters here.
An experienced TV technician may have luck identifying the place and applying physical force there so that it doesn't detach.
However, it's a technology issue and if it has happened in one place of the LCD it will happen in another over time.
Contrary to what popular belief is competition isn't all good for customers.
Competition leads to lower prices and from there to lower quality.
All consumer electronics - and particularily the TVs - are an excellent example of this.
Not sure I helped you much, but hey, don't kill the messenger.
For more insights see http://www.coppelltvrepair.com .
Posted on May 22, 2011
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 29, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a 52in lcd tv and when you turn it on they are small colored vertical lines going down the left hand side but after about 20 minutes the go away. What is the problem
I would check the LVDS cable from the main board to the t-con board and the ribbon cable from the t-con board to the LCD display for good connection. Be very careful not to damage any of these. Sometimes they become corroded.
Dec 10, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Oct 09, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080.
I assume your Misubishi is not close to anything electrical. However, it sounds like you have had an interference for some time. This will ineviteably cause the HDTV LCD to collapse. LCD's don't respond well close to heat. Is there a vent close? LCD's do well in a properly vented area but with all this said.......they will pick up interference from anything electrical. A few questions to ask ones self........are there any wireless devices or chargers close to the LCD? Might there be an oven, a/c unit or other wiring with 220 volts anywhere close to the LCD such as in the wall?
The Mitsubishi LT is a very reliable, multi component ready set that allows great viewing with surround sound. However, stop and think about this interference. It is not something in the unit. It is an interference. Look hard and when you've discovered it.....you won't believe how crystal clear this set will be.
Let me know what you find...Thanks for using Fixya and add any comments that may help us help you.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Mitsubishi WD52527 Pinstripe vertical red lines
Is the set blurry with pinkish color and white lines?
Dec 21, 2007 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi LT-40133 40 in. LCD HDTV Logo
233 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
